captdownshift (Forum Supporter)
captdownshift (Forum Supporter) UltimaDork
8/23/20 6:26 p.m.
Back in the day it was Uego, LC-1 or LC-2, with coyote powered mustangs using widebands from the factory, I wasn't sure if there was an OE replacement that people adapted, or if there was a new preferred to go.
bgkast (Forum Supporter)
bgkast (Forum Supporter) PowerDork
8/23/20 10:45 p.m.
I'm interested in this, since my LC1 seems to be dead.
Patientzero
Patientzero HalfDork
8/23/20 10:57 p.m.
Other than what you listed the only other thing I've seen people using are Ballenger.  I still have a Uego in my Mustang and use a LC-2 with HP Tuners.
https://www.bmotorsports.com/shop/index.php/cPath/103_241
jerrysarcastic (Forum Supporter)
jerrysarcastic (Forum Supporter) Reader
8/24/20 4:23 a.m.
I use an AEM Uego kit like this one with good results.
AEM Uego Gauge (30-4110NS) and Bosch Wideband Sensor (17025) Kit
Admittedly, I don’t ask much of it since I run a carburetor and just use it for jetting/tuning, and the rest of the time it’s only there to warn me if I am running lean for some reason.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) Dork
8/24/20 7:48 a.m.
14point7 Spartan series are my favorite "cheap" ones, but the LC2/MTXL seem to be a lot better than the LC1 for sure. PLX and Zeitronix were my go-to for mid range, but usually just jump to an AFX/AFR500v2 with NGK sensor from the cheap ones.
JoeTR6 (Forum Supporter)
JoeTR6 (Forum Supporter) Dork
8/24/20 7:54 a.m.
I'm running an MTXL in my MSM.  After 8 years and 80k miles, it's still working.
8/24/20 9:26 a.m.
The DSM has a PLX controller in it. I don't really know anything about it, or if they're still available, but it seems to work.
8/24/20 12:04 p.m.
I found an open source controller for $45 that I'll take a gamble on, for challenge reasons.
8/24/20 2:25 p.m.
Make sure you calibrate it by reading plugs often.
alfadriver (Forum Supporter)
alfadriver (Forum Supporter) MegaDork
8/24/20 2:33 p.m.
Link?
8/24/20 2:37 p.m.
In reply to alfadriver (Forum Supporter) :
See attached
8/24/20 2:40 p.m.
That one should be mostly fine, but discontinued, not sure how support is.
LrkR9UYsdt2X2SHZgVNyJwMVUQAqzKJaQrfJWa9WfhIQwCnHoS0sKYS3JTkboe5Y
