JG Pasterjak
1/5/24 8:35 a.m.
It would be nice if we could shift our MR2’s gears, right?
In the last update on our 2GR V6-swapped 1991 Toyota MR2, we left things hanging a bit after we installed the shift linkage and rebuilt the transmission bell crank. We had smooth actuation of the cables, but the linkage seemed to be…
eurichs07
eurichs07
1/5/24 1:29 p.m.
My 1991 MR2 with a 2GR/S54 also seems to bind shifting from 1st to 2nd. I thought it was maybe a combination of my syncros and the higher 7200 rpm readline.  I also have MR2Heaven cables with spherical ends, drop plate, adjustable shift lever and solid shifter mounts. Guess I will have to look into shortening the cable if that seemed to help you.  Are you using a S54 or E153 transmission?
JG Pasterjak
1/5/24 1:59 p.m.
E153.
If the stick moves side to side just fine but front to back is an issue, yeah, check that passenger side cable.
1/6/24 3:45 p.m.
I'll just sit here and marvel at the bolts and cables on that shifter that are cad plating colored instead of rusted all to heck.
clutchmaster
clutchmaster New Reader
8/30/24 3:10 p.m.
I have a 2gr swapped MR2 also. It has trouble coming out of reverse. How did yours behave before you trimmed the cable? I guess I'm asking, what "kind" of binding did you have? If that makes sense?
thanks
Clutchmaster
iGSDgAUWKFt2SkZDgirefOpNWQqggdph4qAKujVAruqTzcN4AkT5fxMDgDyoBBen
