Toyman01
Toyman01 MegaDork
10/4/16 9:35 p.m.
I need a engine. 4 cylinders. Light weight. Simple enough to transplant into a boat. 125-175 hp.
I'm looking a Suzuki engines, but what else is out there. Weight is the biggie.
It also needs to survive extended runs in the 4000-5000 rpm range.
Toyman01
Toyman01 MegaDork
10/4/16 9:36 p.m.
And cheap. I like cheap.
Toyman01
Toyman01 MegaDork
10/4/16 9:37 p.m.
It would get mated up to this.
MrChaos
MrChaos HalfDork
10/4/16 9:42 p.m.
would the g13bb get you into that range or would you need something like the j18 from the sidekick sport.
BrokenYugo
BrokenYugo UltimaDork
10/4/16 9:46 p.m.
Honda B series? Google says it's only 350lbs complete and with trans, so like 290 without.
edit: B not D, not enough power in the D series. Also, add weight for VTEC, but the cheap ones won't have VTEC.
Mike
Mike Dork
10/4/16 9:49 p.m.
MrChaos
MrChaos HalfDork
10/4/16 9:54 p.m.
what about motorcycle engines?
Toyman01
Toyman01 MegaDork
10/4/16 10:01 p.m.
MrChaos wrote: what about motorcycle engines?
Expensive. Yamaha makes a complete setup using their 1000cc and 1200cc inline 4 cylinders. The engines, used go for $2000K and up. I'm thinking more along the lines of a $300 engine.
Raze
Raze UltraDork
10/4/16 10:03 p.m.
In reply to Toyman01:
MR1 HO from 2004 to 2008 was 1L making 160HP at 10k rpm...
Cheap, light, powerful...pick two
Toyman01
Toyman01 MegaDork
10/4/16 10:04 p.m.
Doesn't some of the Honda stuff turn backwards?
I like the idea of a 8500 rpm redline.
MrChaos
MrChaos HalfDork
10/4/16 10:08 p.m.
what about a g10t? it does iirc 75ish hp stock but can hold ridiculous amounts of boost.
Toyman01
Toyman01 MegaDork
10/4/16 10:11 p.m.
Raze wrote: In reply to Toyman01: MR1 HO from 2004 to 2008 was 1L making 160HP at 10k rpm... Cheap, light, powerful...pick two
This I know. That's a $3000+ ski around here, and at that price, beat hard.
I'm thinking more along the lines of sub $1K for the engine and pump and the pump is $250.
Toyman01
Toyman01 MegaDork
10/4/16 10:12 p.m.
In reply to MrChaos:
I need to give a shout out to Zomby.
MrJoshua
MrJoshua UltimaDork
10/4/16 10:17 p.m.
What operating rpm range do you want? Do you want that 125-175hp in the 4000-5000rpm range?
MrChaos
MrChaos HalfDork
10/4/16 10:18 p.m.
also iirc a g10t wet is very light as it is all aluminum
Toyman01
Toyman01 MegaDork
10/4/16 10:19 p.m.
Geo Metros are cheap. Like sub $500 cheap.
MrChaos
MrChaos HalfDork
10/4/16 10:22 p.m.
the issue is finding a turbo one though. I mean most are either g13a/b's or g10 non turbos with their 50hp
bigdaddylee82
bigdaddylee82 SuperDork
10/4/16 10:23 p.m.
Wankel?
Not near the HP, but those mil surplus air cooled flat 4s that the air boat guys use, 4A084? They were in planes and gen sets, and various power units. They seem to motivate air boats well, not sure if the same principles apply to jet pumps?
Gearing and a little Kubota diesel? There's a Yanmar or similar little diesel in most of the refer trailers, a lot of scrap trailers to get little diesels from.
Toyman01
Toyman01 MegaDork
10/4/16 10:23 p.m.
In reply to MrJoshua:
I could probably stand that to be in the peak areas at the top of the RPM range. Yamaha is getting 160 out of their 1L engines by spinning them 10K. Their newer stuff is coming with 1.8L engines. They are also burning a ton of fuel. 13+ gallons per hour.
I don't mind sacrificing some speed for economy and range.
MrChaos
MrChaos HalfDork
10/4/16 10:25 p.m.
Zetec is like 260lbs
LanEvo
LanEvo Reader
10/4/16 10:28 p.m.
The BMW M10 is supposed to be 83 kg (180 lbs) and is about as simple and reliable as you can get. They only make about 100 hp stock, but can be tuned to make more power without great expense.
Toyman01
Toyman01 MegaDork
10/4/16 10:28 p.m.
MrChaos wrote: In reply to Toyman01: the issue is finding a turbo one though. I mean most are either g13a/b's or g10 non turbos with their 50hp
With the engine prices, I boost a n/a one till it blows and back off a little.
BrokenYugo
10/4/16 10:29 p.m.
Junky turbo setup on aforementioned 50hp G10? The whole lakewater cooling deal should help here.
Toyman01 wrote: Doesn't some of the Honda stuff turn backwards? I like the idea of a 8500 rpm redline.
Yeah, that would be a problem. The K series spins normally though, something like 350lbs complete.
mad_machine
mad_machine MegaDork
10/4/16 10:35 p.m.
the beauty is.. you are on a boat. You do not need to worry about NVH, Emissions, or even power band. You can take almost any small 4 cylinder and get into the range of power you want simply with the use of cams, porting, and proper carburation.
Boats are highly tolerant of poor drivability, simply because they move in a fluid environment that allows the prop (or pump) to slip instead of trying to supply power to a hard surface.
The bad news is.. you are on a boat. Engines on a boat take a serious beating and if you are in salt water and using raw water cooling, all that salt is going to eat the aluminum block and head
bigdaddylee82
10/4/16 10:41 p.m.
From a random post on a random Subaru forum that Google fetched for me.
EJ-22: 2,2 liter, 130 to 160 hp, about 120 kg(265lbs) dry weight
EJ-25: 2,5 liter, 165 to 200 hp, about 135 kg(298lbs) dry weight
KY4b745r9NYmjpBQLG051esWLo9Z3MqXO0nyzrTAfKBIHBjUGW63o3qnhyW79zAS
