SVreX
SVreX SuperDork
8/26/08 1:51 p.m.
I'm looking for a junkyard set of steelies. 15" x 7" with a 4 x 114.3 bolt pattern (the same as a 4 x 4 1/2")
Prefer a large offset, like 35- 40 mm
I find plenty of 5 ligs, but no 4 lugs.
Help!
SVreX
SVreX SuperDork
8/26/08 1:53 p.m.
Actually, I don't care if they are steelies. The lighter, the better.
Gimp
Gimp Dork
8/26/08 1:55 p.m.
Hyundai Tiburons/Elantras... I "think" there may have been a 15x7
ClemSparks
ClemSparks SuperDork
8/26/08 1:58 p.m.
I don't know if they were 7 inches wide, but the '87 Acura legend I junked had a set of 15" 4 x 114.3 wheels. Apparently it's a "Sterling" basically. I've kept them in case they'll fit something, but I doubt anythink I'd get would use them (except my rear drive Corolla's and spacers...to much $).
Clem
Gearhead_42
Gearhead_42 HalfDork
8/26/08 2:00 p.m.
S13 240SX
I have a set of 4 alloys... come get 'em.
Salanis
Salanis Dork
8/26/08 2:01 p.m.
Honda Accord, Most Nissans. They may not be 7" wide though. I think those are 6-6.5" wide.
ReverendDexter
ReverendDexter New Reader
8/26/08 4:12 p.m.
RWD Celicas and Supras
Edit... err, you said large offset, nvm.
SVreX
SVreX SuperDork
8/26/08 4:15 p.m.
Gearhead_42 wrote: S13 240SX I have a set of 4 alloys... come get 'em.
You've got a PM
bluej
bluej Reader
8/26/08 4:41 p.m.
are you positive they are 15x7 and not 15x6? was searching car-part because of your post and everything came up 15x6... i need 15x7 4x4.5 as well.
thatsnowinnebago
thatsnowinnebago Reader
8/26/08 4:58 p.m.
RX7 GSL-SE?
16vCorey
16vCorey Dork
8/26/08 5:02 p.m.
According to my manual, the only 15x7 4x4.5 factory wheels to come out in the last 30 years or so, was an option on a '00-'06 Sentra.
SVreX
SVreX SuperDork
8/26/08 5:25 p.m.
16vCorey wrote: According to my manual, the only 15x7 4x4.5 factory wheels to come out in the last 30 years or so, was an option on a '00-'06 Sentra.
What was the "standard"?
RedS13Coupe
RedS13Coupe New Reader
8/26/08 5:27 p.m.
IIRC the standard wheels were 6, the SE wheels were 6.5 ... if not they were all 6.5 Close, but not 7.
Gearhead_42
8/26/08 5:27 p.m.
I think maybe your manual is in error:
If I am reading all the gobbledygook on the rim correctly, these are 15x7 with a 40 offset...
Gearhead_42
8/26/08 5:30 p.m.
OK, maybe not... but anyway, that's the wheels I got, that's what the tape measure says across the outer rim surfaces, and the "40" is cast in just inside one of the teardrops...
RedS13Coupe
8/26/08 6:17 p.m.
yeah the offset is +40....
Rim width is measured from bead flange to bead flange, not from the outside.
egnorant
egnorant Dork
8/26/08 11:28 p.m.
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm
I looked around on here but didn't find any 15x7. found a lot of 15x6.5.
I suspect some "upgrade" models may have had larger.
Bruce
57P64tL94w52KaMTEU51B8JKhxpWDA28kNA5XuQ1IOCrI8hE8uBJXd0ydYTGsGpE
