jonnyd330
jonnyd330 Reader
4/6/24 7:23 p.m.
I recently just got a square 17x8.5 Apex ARC-8 wheel setup for my e46 330i track car (HPDE) and I am wondering what others run for tires. I was just going to get a 245/40 17 but then I was wondering if a 255 would fit without rubbing. I have a track aliment and setup with 3 degrees of camber up front and 2.5 degrees in the rear. I have not rolled any of the fenders.
I am curious what others have run without rubbing?
Sonic
Sonic UberDork
4/6/24 8:23 p.m.
In my e36 M3, which is quite similar, on the same size wheel, a 245/40 17 worked very well all around.
jgrewe
jgrewe Dork
4/6/24 9:46 p.m.
Spec E46 uses 255/40/17
CyberEric
CyberEric SuperDork
4/6/24 9:57 p.m.
What offset are the wheels?
I had 255/40 17s on my E36 M3 with no fender rolling. Wheels were 17x9. I believe offset was 44, but it was 15 years ago so I could be off. On 8.5s, I'd probably go with the 245.
LukeGT
LukeGT New Reader
4/6/24 10:00 p.m.
I recently bought an E46 330ci ZSP that came on a set of 255/40/17 Falken 660s. Car is lowered on some Bavauto lowering springs and has some camber plates up front, doesn't rub at all and handles exceptionally well.
jgrewe
jgrewe Dork
4/6/24 10:20 p.m.
In reply to CyberEric :
I just bought ET42 offset based on Bimmerworld's rims offered for the cars in the class.
jonnyd330
jonnyd330 Reader
4/6/24 10:28 p.m.
Offset is 40
id assume most spec e46 cars have rolled fenders. Please correct me if I'm wrong.
jgrewe
jgrewe Dork
4/6/24 10:37 p.m.
Probably, I haven't finished my car enough to fit the rolling stock on it.
codrus (Forum Supporter)
4/7/24 12:39 a.m.
I have fit 275 Hoosiers (and 295 Toyo RRs) on mine, but A) it's an M3 and B) the fenders have been heavily massaged (paint work required afterwards).
Hoosiers:
Toyos:
Both on 18x10s.  The 295s could probably have done with 11s, but I only ran them the one time.
rslifkin
rslifkin PowerDork
4/7/24 9:52 a.m.
I've seen 255/40R17s done on 17x8.5s (square style 68s with a small spacer in the front) and no rubbing issues.  No fender massaging was required for that.
CyberEric
CyberEric SuperDork
4/7/24 1:07 p.m.
I'm remembering I did have a small spacer on the front of my car, think it was like 10mm.
I can never remember if 40 is further out or in board compared to 44 ET....
Olemiss540
Olemiss540 Dork
4/7/24 2:33 p.m.
Hoosiers:
Toyos:
OP,
With fender flares and you can fit 295s. Hope this helps :-).
amg_rx7 (Forum Supporter)
amg_rx7 (Forum Supporter) UltraDork
4/8/24 12:54 p.m.
For 8.5" wide wheels, I'd do 245s
jonnyd330
jonnyd330 Reader
4/8/24 1:27 p.m.
thanks all
dyintorace
dyintorace UltimaDork
4/11/24 2:02 p.m.
I'd love to see some pictures of what car you ended up buying.  Especially if it is a sedan, as they make sexy track cars!
z31maniac
z31maniac MegaDork
4/11/24 2:31 p.m.
From the ARC website:
  • Front & Rear: 17x8.5” ET40 with 235/40-17 tires
    • Direct fit.
    • Available in: ARC-8
    • 235/45-17 tires can also be used as a direct fit.
    • 245/40-17 tires are often a direct fit, but may require a small front spacer depending on tire brand and suspension setup.
https://apexwheels.com/fitment-guides/bmw/3-series/bmw-e46-3-series-wheel-and-tire-fitment-guide#performance-street-and-track
They mention suspension since coilovers typically have smaller ID springs allowing more inboard clearance.
ATCoPwmlDl4vTqecf2SRNKtmnOxmIHZzawD8r949QmOViKAqfeDUcqkgvRPDPiW7
