dxman92
dxman92 New Reader
7/28/09 7:21 a.m.
Might be looking at a 97 Altima for my younger brother as a beater. It has 150k on the clock. They are asking $600 for it. Any big things I should look out for on these..
The Brown Stig
The Brown Stig SuperDork
7/28/09 7:53 a.m.
Wheel bearings, auto transmissions and mass air sensors are what I have seen.
16vCorey
16vCorey SuperDork
7/28/09 8:22 a.m.
The distributors are also crap. Nothing to really look for, as they spontaneously fail, but just keep $100 in you budget for one.
4cylndrfury
4cylndrfury Dork
7/28/09 8:27 a.m.
power steering high pressure hoses fail a lot in 90s Nissans, and are aftermarket unobtanium. Like $400 from the steelership. But Im sure some grassrotsy types have got easy fixes...if only we knew some of those types of folks
jrw1621
jrw1621 HalfDork
7/28/09 8:29 a.m.
The engine is a timing chain not a belt so it does not need to be changed often like a belt.
belteshazzar
belteshazzar Dork
7/28/09 8:53 a.m.
but there's an o-ring in the timing cover that will fail sometimes and you'll loose a lot of oil. cheap time consuming fix you can ignore as long as you keep oil in it.
can't say I've seen many (any?) transmission failures. I know they're not interchangeable, but the transmission is very similar to the one in the maxima.
seen some dead distributors. seen some bad injectors.
not much else. great car from a reliability standpoint. same mpg as a maxima with less power, but at that price who cares.
fastmiata
fastmiata New Reader
7/28/09 8:08 p.m.
My wife's 94 SE lasted 192k on the stock clutch and other hardware. Other than oil changes, brakes, tires and one engine tune-up, the car never had any significant work done on it. A great car but boring.
OJJzd1RK0xbHs9v7A5xFWhM9Kn6vMFNLxayEj9zRuuHlHL3fN859lojKBmfmEgQO
