porksboy
porksboy SuperDork
8/5/11 10:01 p.m.
What wheels/ cars share the same bolt pattern as a 90 CRX? I saw a late model Civic with steel wheels the other day. It had 4 lug nutsat 15" diametre and the wheels were a dead ringer for my factory steelies in 13" diametre. I am going to go to pull-a-part and see what I can find but want to know if they will fit. Is there a data base where I can cross reference the info? I think pull-a-part has an interchange data base but i want to know if there is any thing in the yard before I go down there. Thanks in advance.
RexSeven
RexSeven SuperDork
8/5/11 10:29 p.m.
Bolt pattern on EF-chassis CRX/Civics is 4x100mm. Wheels from any 4-bolt Civic or Integra should work.
KATYB
KATYB HalfDork
8/6/11 1:24 a.m.
what rex said if its 4 lug and honda it most likely fits perfect.
ValuePack
ValuePack Dork
8/6/11 2:10 a.m.
4 bolt Honda Civic/Integra(not Accord), Miata, VW Golf/Jetta thru '99.5(except VR6), Toyota Tercel/Corolla should all work well. There are plenty of others I'm forgetting...
jrw1621
jrw1621 SuperDork
8/6/11 2:14 a.m.
From this list you should manually be able to find what fits. Be sure to pay attention to Center Bore size.
http://adaptitusa.com/referencebook.htm
An easy answer for you is BMW 4x100 "Bottle Cap" wheels from am '84 to '91 BMW 3 series.
4 rims with tires for $250
http://atlanta.craigslist.org/nat/pts/2525100803.html
$75 for 5
http://atlanta.craigslist.org/nat/pts/2526426491.html
Full part-outs:
http://atlanta.craigslist.org/atl/pts/2531392604.html
http://atlanta.craigslist.org/atl/pts/2516055024.html
KATYB
KATYB HalfDork
8/6/11 2:22 a.m.
EGT FANBLADES!!!!!!!
DeadSkunk
DeadSkunk HalfDork
8/6/11 6:30 a.m.
I believe that Honda hubs are 56 mm diameter. My Miata and Scion (Toyota) rims are all 54 mm diameter for the center hole. They won't go on a Honda, or my MINI for that matter. VWs are 57 mm,MINIs and Hondas are 56mm,Toyotas and Kias are 54mm. I can't speak to the hub diameter on any other brands.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
8/6/11 6:51 a.m.
KATYB wrote: EGT FANBLADES!!!!!!!
This, preferably the 1993 variant, since they were the best!
Tom Suddard
Tom Suddard SonDork
8/6/11 7:12 a.m.
BMW basket weaves will fit great, too.
mw
mw HalfDork
8/6/11 10:08 a.m.
In reply to 92CelicaHalfTrac:
I'm pretty sure EGT used the 54mm hub bore, so they won't fit a honda without machining.
CanadianTercel
CanadianTercel Reader
8/6/11 2:12 p.m.
Most German stuff is 57.1, Mazda and toyota at 54.1 and Honda is 56
KATYB
KATYB HalfDork
8/6/11 2:15 p.m.
easy enough to hone out the bore by 2 mm tho to make them fit. and yes 93's were the best. didnt some years not even come with them directional side to side wise.
mad_machine
mad_machine SuperDork
8/6/11 3:29 p.m.
why is it that bottlecaps looks good on everything BUT bmws?
porksboy
porksboy SuperDork
8/6/11 11:12 p.m.
Arent bottle caps 14"? Im looking for 15" steelies that look similar to my factory steelies.
I thought that any Honda lug would work. Im off to the junkyard first chance I get. Maybe Ill find some with usable rubber on them.
CanadianTercel
8/7/11 7:11 p.m.
Don't get accord or prelude stuff!! And stay away from Nissan, Mitsubishi and fords
ix5ZPsX5DwCxZ0gjs0lzHAAOuhIBTeyRfX2iQ6dC0944eLlgSVsuWiBzBNzs8fGQ
