Dusterbd13
Dusterbd13 UltimaDork
9/19/17 4:27 p.m.
So, the 99 miata sticker says sport s suspension.  My 2000 says std.
Google seems confused about this. No real answer.
I know the 99 has a torsen differential and leather. Brakes fit under 14 inch steel wheels.
What is the other differences? I havent found any additional chassis bracing, the shocks are black and factory.  I was under the impression that the sport included bilsteiens and stiffer spring rates and bracing, but that seams to overlap with the hard s suspension.
Whats the real breakdown here, and what is the good stuff for the daily?
steronz
steronz Reader
9/19/17 4:38 p.m.
From a random miata.net thread, seems accurate:
STD S had the 14" wheels
SPORT S gave you the 15" rims (same springs and shocks as STD-S)
HARD S was the Sport Suspension Option, Bilestin shocks, Sport springs, 12mm rear bar and STB.
9/19/17 4:42 p.m.
They're all 17 years old at this point. I'd be considering what I'd put on to replace the worn stock stuff instead.
codrus
codrus UltraDork
9/19/17 4:42 p.m.
(deleted redundant and not entirely accurate suspension info).
All NB1s (99-2000) have the same bracing and the same brakes, the brakes are common with the 94-97 cars and will fit under 14 inch wheels even on cars that came with 15s from the factory.  The bigger "sport" brakes showed up in NB2s (2001-2005), as did the additional bracing.
Dusterbd13
9/19/17 4:49 p.m.
Ok. Thanks y'all.
It really didn't feel any different or appear any different, but I wanted to be sure.
8UTOSG7x2sOOL3aKb3d7XNPrA82OpldfACReAjAeD39Q0MSWkhEvTrEWifSiir0a
