olpro
olpro New Reader
12/17/13 2:54 p.m.
I am looking at the wheel alignment of an exo-car (RCR Superlite Razor) and would appreciate some basic guidelines. Any ideas for a good starting point for things like toe-in/out, etc.??
SVreX
SVreX MegaDork
12/17/13 3:23 p.m.
This interests me...
DeadSkunk
DeadSkunk SuperDork
12/17/13 3:44 p.m.
Paging Kurt to the white courtesy phone !! A Razor is basically , kinda, like the Midlana, sorta,maybe.
Conquest351
Conquest351 UltraDork
12/17/13 5:21 p.m.
Maybe zero everything out first and add (or subtract) a little negative camber, maybe a degree at most, then go test drive. I would think your toe settings would want to be at zero to start with.
Also, congrats on the Razor. Where's the build thread?
z31maniac
z31maniac UltimaDork
12/17/13 6:41 p.m.
No idea how similar it is to a Miata, but I my track settings for the Miata are:
0 toe, F/R
-3° camber front, -2.6° camber rear
No idea on caster, basically told the guy as much as we could get once we hit the camber target.
JKleiner
JKleiner Reader
12/17/13 7:26 p.m.
See if Fran at RCR has a recommendation but if not for a baseline I'd probably start with around a degree of negative camber and if adjustment range will allow it without the steering effort becoming too great try for 5-8 degrees positive caster. Zero or toe out will tend to make it a little darty and lacking in straight ahead stability (although it will bite a bit better on turn in) so I'd go for ~3/32"-1/8" toe in.
Jeff
olpro
olpro New Reader
12/18/13 9:22 a.m.
Thanks everyone. (Build thread at http://www.exocars.net/showthread.php?t=14577&page=24 )
Conquest351
12/18/13 9:47 a.m.
Very cool. Haven't been on ExoCars.net in a while. Need to get back on there and see all the eyecandy. LOL
qmcGEVA8ZOCJtyOy5JGT4rzoeT0Qu430z14Jh11DaDhmySCJsOgLA0FXzratnZif
