Treb
Treb Reader
2/16/10 7:51 a.m.
So there'a a road I drive every afternoon, and there's a pattern of skidmarks on that road that is 20+ miles long. And every day, I start to wonder what would make it happen.
The skidmarks begin on one highway, take the same exit as I do onto another highway.
The marks are made by one wheel, locking and releasing.
The marks get closer together on the ramp -- down to a few feet apart -- and are 20-25 feet apart on the highways. At reasonable highway speed, it would be 3 or 4 cycles per second. Each mark is maybe a foot or two long.
So what would cause one wheel to lock and release at 4 hz for 20+ minutes?
John Brown
John Brown SuperDork
2/16/10 7:56 a.m.
Are you sure it is wheel lockup and not a "line erasure"? Sounds like someone removed a dotted line.
If not it could be a trailer with a bearing locking up.
Luke
Luke SuperDork
2/16/10 7:58 a.m.
Extreme axle tramp?
DrBoost
DrBoost Dork
2/16/10 7:58 a.m.
Yeah, I think it was a wheel locking up on a trailer.
Gearheadotaku
Gearheadotaku HalfDork
2/16/10 8:26 a.m.
Some trucks can lift an axle when not needed. Once in a while they droop down a bounce off the road. If the systems not right, they skip along and leave marks like you describe.
Treb
Treb Reader
2/16/10 8:41 a.m.
JB -- it's a tire. It changes lanes on highway #2, and it is consistently in the right-hand side of the lane, or the ramp. And would a bearing locking up be at regular, not speed-related, distances?
Gearheadotaku -- I like that explanation. Slower speeds mean less energy in the bounce, so closer together on the ramp between the two freeways.
mad_machine
mad_machine SuperDork
2/16/10 8:55 a.m.
In have seen some of the "sailors" here with faulty trailer brakes under the boats pull them for MILES until they have a blow out...
foxtrapper
foxtrapper SuperDork
2/16/10 9:22 a.m.
I also suspect a trailer. With tramp and a semi-locked wheel. Bouncy bouncy bouncy, chirp-chirp-chirp.
iceracer
iceracer HalfDork
2/16/10 9:56 a.m.
Empty trailers often do that. See them all the time.
Duke SuperDork
2/16/10 11:22 a.m.
Especially if it was a 2-axle trailer and only had the issue on one wheel, with the other carrying part of that side's load.
Jerry From LA
Jerry From LA HalfDork
2/16/10 11:41 a.m.
Whew. From the thread title, I thought for a second that someone could look at my underpants and see the future.
4P0ZQAgKLU7teNBgQiQhSDa0aZGHln2gDLdmT7tyzoWV0BsD6aqKAytXDSxwZKFT
