Gearheadotaku
Gearheadotaku PowerDork
1/29/15 2:04 p.m.
Or 'learn me
Backspacing vs. offset. How does this work? Can one value be used to determine the other? Often I see one listed, but not both. Haven't been able to comprehend what I've read elsewhere.
EvanB
EvanB UltimaDork
1/29/15 2:13 p.m.
Wheel offset is the distance from the wheel mounting surface (that contacts the hub) and the centerline of the wheel.
Backspace is the distance from the wheel mounting surface to the back lip of the wheel.
FSP_ZX2
FSP_ZX2 Dork
1/29/15 2:13 p.m.
1/29/15 2:18 p.m.
1/29/15 2:39 p.m.
If you have two of the following, you can calculate the third: backspace, offset, wheel width. Just make sure you account for the thickness of the lip, as that's not part of the wheel width.
Driven5
Driven5 HalfDork
1/29/15 5:09 p.m.
Keith Tanner wrote: Just make sure you account for the thickness of the lip, as that's not part of the wheel width.
Just to reiterate the effect that this has, lip thickness is usually assumed to be ~1/4". So a 10 inch wide wheel with 0 offset will actually be expected to have ~5.25" backspacing.
UUGu2D3QzgnM6YQNtL0439BqOLZhN38Jwf16VmxMPn3RWSg9EUOMZDKnVPB6Q5Z2
