porksboy
porksboy Dork
7/16/10 9:50 p.m.
Murphy is a bitch.
So this morning at 5:00 AM my wife, daughter, and myself left Atlanta bound for Miami. We didnt even get out of the drive way before the cars headlights quit. I found the problem but count get the part to repair it. We waited til it was light then hit the road. Made it here in one piece in the daylight.
I found the problem before we left. It seems that Mercury buts what is called a Lighting Controle Module on the 2004 Grand Marquise that among other things has the high and low beams running thru it. When the lights are out a sharp whack with the butt of my pocket knife brings the lights back on for a while. Looks like a sticky or dirty contacts on a relay in there. Guess I gotta find one tomorrow.
I went on a beer run when we got here. That was fun.
irish44j
irish44j HalfDork
7/16/10 10:07 p.m.
this is GRM. You should have just used a pair of mag-lites...
Tommy Suddard
Tommy Suddard SonDork
7/16/10 10:11 p.m.
Even that's too expensive. Buy some bulbs and switches at radioshack, find some aluminum pipe, and make your own mag-lites!
mndsm
mndsm HalfDork
7/16/10 10:16 p.m.
No way- that's not creative enough. You need to retrofit some electric coleman lanterns you found in the trunk of a derilect you adopted and fabricate projectors out of an eBay set of Honda headlights.
slantvaliant
slantvaliant HalfDork
7/16/10 10:55 p.m.
Freebie Harbor Freight flashlights FTW.
MitchellC
MitchellC Dork
7/17/10 12:36 a.m.
Set off signal flares every few hundred feet to indicate your presence and trajectory.
zomby woof
zomby woof Dork
7/17/10 6:33 a.m.
Use the above mentioned aluminum pipe to build a launcher, and shoot the flares ahead to indicate your presence. You should get noticed.
gjz30075
gjz30075 Reader
7/17/10 6:50 a.m.
Get a horse!
dimarra
dimarra Dork
7/17/10 9:37 a.m.
The "lighting control module" on my Continental went bad too. Rather than shell out $500+ for a replacement, I took the thing apart.
The only problem was a bad solder joint where the terminal met the PC board. Mine was an easy, cheap fix.
porksboy
porksboy Dork
7/17/10 4:23 p.m.
A coil of wire and I would have been set. I didnt want to hack together a fix for a car I was making a long trip with my wife and child in. A new module at the stealership and 5 minutes under the dash and I was done. The stealership parts dept was great. They gave me a new one for less than a reman from Rockauto. It was the one in Delray Beach.
GjD5Lo5B13OXUVWzRzIC6dyrjP4DMLlpNJAwBwf4spxhVYK5uFyU06RCYdIjDVoZ
