92dxman
92dxman Reader
10/16/08 8:49 a.m.
I need to replace either a blown fuse or relay to the fuel system in my Escort. Where would I be able to find a wiring diagram online instead of having to dish out for a Haynes Manual?
nickleone
nickleone New Reader
10/16/08 10:47 a.m.
The public library in the reference section. Mitchels books?. bring a roll of dimes for the copier.
Dr. Hess
Dr. Hess SuperDork
10/16/08 11:49 a.m.
Go to autozone.com. Add whatever Ford you are beating on. Click Repair Info on the left. Click Vehicle Repair Guides. Click Chassis Electrical, then over on the right, Electrical Diagrams.
Here's '91-'99 (I figgered no Ford older than '91 would still be on the road anyway) : http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008debf
MiatarPowar
MiatarPowar HalfDork
10/16/08 11:53 a.m.
Maybe one of the many Escort forums could help? I used FEOA years ago. I really don't even know if it's still around.
John Brown
John Brown SuperDork
10/16/08 12:58 p.m.
Dr. Hess wrote: Go to autozone.com. Add whatever Ford you are beating on. Click Repair Info on the left. Click Vehicle Repair Guides. Click Chassis Electrical, then over on the right, Electrical Diagrams. Here's '91-'99 (I figgered no Ford older than '91 would still be on the road anyway) : http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008debf
I saw a Toyota pickup being flat towed by an early '80s F150 this morning.
ClemSparks
ClemSparks SuperDork
10/16/08 1:23 p.m.
The fuse block under the hood has the fuse for the fuel system, and the cover for the fuse block usually has a legend on it.
As for wiring diagrams. If you want a manual, what you're looking for is the EVTM from Ford. That's an "Electrical Vacuum Troubleshooting Manual."
Clem
Edit: Here's a thread on TurboFord where I got my problem figured out. The wire between the relay and the pump burned up completely. I just basically ran a new wire (like mentioned in the other thread you had about this one): http://www.turboford.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=15;t=001536
Dr. Hess
Dr. Hess SuperDork
10/16/08 1:33 p.m.
John, you sure the Toyota wasn't pushing the Ford?
I do think that Ford trucks were pretty good.
ClemSparks
10/16/08 1:56 p.m.
haha...I just figured out if you put "Edit" in square brakets...it hides anything in the post you type after that!...
egnorant
egnorant Dork
10/16/08 8:53 p.m.
Did you check your inertia safety switch?
Bruce
Jensenman
Jensenman SuperDork
10/17/08 2:09 p.m.
Also, late '80's to mid '90's Ford stuff had fuel pump relays made of rock candy. Many of them just hung in the wiring harness and would fill with water; I had a buddy whose Ranger was continually stalling. I lifted the relay to the vertical position and rusty greenish water started dripping out of it. The relay casing is either blue or green, I forget which.
The later ones had power distribution blocks that used a cheapo version of the ubiquitous Bosch 'ice cube' relay and they were famous for bad relays and loose mounting terminals due to overheating.
92dxman
92dxman Reader
10/18/08 6:43 p.m.
Upon further examination by my mechanic, its the timing belt. Is the Escort 1.9 motor an interference or a non-interference motor? Also have people had bent valves when the timing belt goes?
Jensenman
Jensenman SuperDork
10/18/08 8:43 p.m.
1.9's are freewheelers.
fr8djydk9AuDTE1vlpCuq8tgREi1nb6oAft6sZ7IKr15xfVsd4nAn2Y6h4XtRPGA
