KyAllroad (Jeremy)
KyAllroad (Jeremy) PowerDork
1/27/18 3:05 p.m.
Ford 302 but Edelbrock Performer heads.  Fuel injected and fairly aggressive cam.  What plugs do I put in this thing?
rslifkin
rslifkin SuperDork
1/27/18 3:30 p.m.
What's the compression ratio?
KyAllroad (Jeremy)
1/27/18 4:47 p.m.
In reply to rslifkin :
ummm...... dunno.
jimbbski
jimbbski Dork
1/27/18 4:58 p.m.
Are the pistons flat top or do they have a dome?
What's the size of the combustion chamber?
Check with Edelbrock if you don't know?
With that info you should be able to figure out C:R.
Also most likely the plugs required will have a gasket and not be a tapered seat as Ford used on may of their cast iron heads.
KyAllroad (Jeremy)
1/27/18 5:22 p.m.
These are the heads and this is a relevant post from 12 years ago that the internet puked up about them.
Bottom end of the engine is factory 5.0 from a 2000 Explorer.
KyAllroad (Jeremy)
1/27/18 5:25 p.m.
OK, so it appears these plugs are the ones to get.  Is there a particular model number that anyone out there recommends?
Dirtydog
Dirtydog Reader
1/27/18 5:26 p.m.
Try stock Autolites, or Motocraft. run them, I forget what the gap is.  The stock plug should be able to handle it.  Pull and read the plugs.
rslifkin
rslifkin SuperDork
1/27/18 6:09 p.m.
Based on all of that, I'd say either a stock plug (or one with the right seat and same tip projection, etc.) or you could go 1 heat range colder for more knock margin.
Ro28wgRC4YKLt5T4axCi01xoJgWUVa3Jg6zQBrrP9fgniRE2dnf6MyBkUBQUBG6a
