RevRico
RevRico UltimaDork
9/25/22 2:31 p.m.
Well I knew it was coming, blew the front to rear line on the excursion.
$180 can get me a pre bent set of stainless lines that supposedly fit for the whole vehicle. I know the ones I bought just for the rear of the Ranger were off which gives me pause on buying a whole vehicle worth.
At the same time, I'd need to buy a double flare tool, sort through all the contradictory sizes of fittings online, and run and bend a whole new line out of copper nickel by hand if I don't buy the pre bent option.
Or sell the excursion for a loss with no brakes and try to replace it in this economy.
So point me in a direction I guess. Splicing out this hole will just move it further down the line, and add more potential leak points at fittings.
matthewmcl
matthewmcl Dork
9/25/22 5:04 p.m.
While they don't have prebent for anything as new as an Excursion, I have been very pleased with the made-to-order lines I have been getting from TheStopShop.com. The copper nickel line is easy enough to bend by hand (so far just 3/16" for me, but I will be getting 1/4" also) that prebent may not be required, as long as you get the length correct.
Noddaz
Noddaz PowerDork
9/25/22 5:35 p.m.
And you use the fittings on each end of the new lines from the truck.  Cut the line of somewhere close to the fitting if you can and remove with a 6 point hi quality socket. $180 can buy you a lot of tools to do the job.  And you will have them for next time.
earlybroncoguy1
earlybroncoguy1 Reader
9/25/22 6:48 p.m.
You can get pre-flared, installed fitting, stainless straight hard lines in several different lengths from several different places - Summit is one. Measure your old lines carefully, order new ones the same length or slightly longer, bend carefully with a tubing bender or tubing pliers.
I swapped stronger axles into my Bronco, I ordered a bunch of different lengths of those and got them to fit the Dana 60 and Dana 44 high pinion axles, GM front and Cadillac rear disc brake calipers perfectly.
Dusterbd13-michael
Dusterbd13-michael MegaDork
9/25/22 7:01 p.m.
I buy from classic tube whenever possible. Generally they fit spot on out of the box. Theres been some wrong ones, but overall more rights than wrong
Toyman!
Toyman! MegaDork
9/25/22 8:11 p.m.
The last set I bought came frome Rockauto. They fit well enough and the price was pretty reasonable.
Ranger50
Ranger50 MegaDork
9/25/22 9:00 p.m.
Inline tube or right stuff for me.... last time I bought a roll of line was from when I worked at the Chrysler dealer.
Curtis73 (Forum Supporter)
9/25/22 10:44 p.m.
Agreed.  Classic Tube and Inline Tube are both top notch.  They'll bend up the whole kit and then put a sweeping bend in it to fit it in the box.  Unfold, install, bleed, done.
ddavidv
ddavidv UltimaDork
9/26/22 7:42 a.m.
The Right Stuff were the only folks who listed lines for my '66 Falcon. The brake lines were 95% accurate out of the box. Just some minor tweak needed here and there.
I ordered a new fuel line also, which wound up being about a foot short and missing some important bends. After contacting them, they took my original and bent one to match. Did not charge me any extra.
I don't mind making metal lines but it's extremely time consuming. My time was easily worth what I paid for the pre-bent lines.
RevRico
RevRico UltimaDork
9/26/22 7:45 a.m.
I typically sell vehicles when they need brake lines because I berkeleying hate them and their constant leaks, specialty tools, and need for perfection.
Only company that has a set for purchase was Dorman, so I bought them. Hopefully I don't come to regret this over the weekend when they come in.
dean1484
dean1484 MegaDork
9/26/22 8:44 a.m.
I will also recommend Inline Tube. Used them a couple times now with out issue.
eLUfg14Mh458DpBrvfG5Kl0aHeNPA37iH7WBHRePFzbQgiQGZG6aimG9cPRaGlR8
