The original distributor in my 93 Civic EX died a bit ago (and it wasn't just the coil) and now my new one is dead (tried replacing the coil and it did nothing). So who makes a decent replacement? Majestic Honda doesn't have any OEM ones or I'd get one of those.
https://www.holley.com/products/ignition/distributors/
You should find the parts by scrolling down to the (near) bottom.
It's probably the Ignition Control Module that failed. Delphi brand on RockAuto is a rebranded Hitachi (OEM).
You think? Does that act the same as a distributor? This is acting like every other Civic where my distributor or ignition coil has gone out.
The ICM is inside the distributor- they burn out and fail. If you replace it and the coil you should be good to go.
Ok cool. I already did the coil so I will get one of those.
logdog
UltraDork
3/16/20 2:19 p.m.
Im my experience unless the distributor is full of "red death", a ICM or coil fixes most ills. I haven't had luck with aftermarket. Customers used to bring in cars with Brand New Distributors from AutoZone and whatnot all the time as no starts. I usually kept a couple functional distributors in the bottom of my toolbox to prove to them the new part was bad.
Also, you gotta call them "Dizzys" if you want to be a cool kid on HondaTech in 2005
Or if you are cool shade tree from 1967.
