xflowgolf
xflowgolf Dork
2/4/14 9:59 a.m.
Neat truck. Seems like something a GRM minded individual would build.
Seems like a hell of a nice usable (sleeper) truck for the money.
http://southbend.craigslist.org/cto/4255868014.html
"99 OLDS BRAVADA WITH TURBO CONVERSION USING GMC TYPHOON PARTS. LOADED WITH ALL THE USUAL BRAVADA STUFF, 130,000 MILES AND NOT A SPOT OF RUST ANYWHERE, VERY WELL CARED FOR. REBUILT TRANSMISSION TO CORVETTE SPECS, FRONT MOUNT INTERCOOLER WITH 10-11 LBS BOOST. HP TUNERS, MARINE INTAKE, 4472 TRANSFER CASE, ALUMINUM DRIVE SHAFT, FIREBIRD POSI TRAC, 2" DROP, 17" CORVETTE WHEELS, BRAND NEW TIRES, EXHAUST, DROP SHOCKS, FRONT BRAKES, ALL MOUNTS, BATTERY, ALIGNMENT"
nmna
conesare2seconds
conesare2seconds HalfDork
2/4/14 10:59 a.m.
THAT is cool; I'd rock it.
Sine_Qua_Non
Sine_Qua_Non HalfDork
2/4/14 11:03 a.m.
That's an ultimate sleeper right there
MudHut
MudHut New Reader
2/4/14 11:42 a.m.
Subtle if you don't know what to look for. He has a few 'tells', but I completely agree with the sleeper comment.
Someone should get in touch with him and see if he will add some detail to this thread.
Jay
xflowgolf
xflowgolf Dork
2/4/14 4:09 p.m.
MudHut wrote: Subtle if you don't know what to look for. He has a few 'tells', but I completely agree with the sleeper comment. Someone should get in touch with him and see if he will add some detail to this thread. Jay
It certainly has a few tells, I just love that it's the Bravada to begin with vs. a Blazer.
Start with the most plush version, and retain Oldsmobile oddity appeal.
You could easily make it more sleepy, but I think the forced Vette wheel mashup makes it a more intriguing head scratcher.
novaderrik
novaderrik PowerDork
2/4/14 7:00 p.m.
why did he have to put the Buick turbo 6 license plate on it?
MudHut
MudHut New Reader
2/4/14 7:25 p.m.
IIRC, That's the origin of the original turbo'ed 231 cu. in. V6 engine. I think he could have also affixed a GTA Trans-am insignia too.
novaderrik
2/4/14 8:11 p.m.
MudHut wrote: IIRC, That's the origin of the original turbo'ed 231 cu. in. V6 engine. I think he could have also affixed a GTA Trans-am insignia too.
the Syclone/Typhoon had a turbo'ed version of the Chevy 4.3 V6, which is a totally different animal than the Buick 231- literally nothing interchanges between the engine families, and they don't even have the same bellhousing bolt patterns..
hence my question about why putting the Buick V6 turbo emblem on the front license plate makes any sense..
MudHut
MudHut New Reader
2/4/14 8:46 p.m.
What was stuffed in the Trans-am GTA of about the same year? Seems it was also a turbo'd six, yes? Just noticed your avatar. Preach it sister!
Jay
novaderrik
2/4/14 9:42 p.m.
MudHut wrote: What was stuffed in the Trans-am GTA of about the same year? Seems it was also a turbo'd six, yes? Just noticed your avatar. Preach it sister! Jay
the 1989 20th anniversary Trans AM GTA had an engine very similar to the 87 Grand National- turbo/intercooled 231 Buick V6 with DIS and sequential MPFI.. but it had slightly better heads than the GN- off the current year fwd 3.8- and a few other changes to make it fit in the F body
Gearheadotaku
Gearheadotaku UberDork
2/5/14 7:29 p.m.
I'm guessing he used that plate because everyone would think "Turbo V6" first and which V6 later.
oldopelguy
oldopelguy SuperDork
2/5/14 8:00 p.m.
Bravada for the AWD instead of 4wd.
novaderrik
2/5/14 8:11 p.m.
oldopelguy wrote: Bravada for the AWD instead of 4wd.
transfer cases swap pretty easily..
yamaha
yamaha UltimaDork
2/5/14 9:18 p.m.
Allegedly the bravada setup was the closest to the syty setup anyways. Pretty sure that an upgraded bravada driveline was underpinning the stealth sonoma that lingenfelter built awhile back as well.
novaderrik
2/6/14 3:20 a.m.
the AWD transfer case in the Syclone/Typhoon was raided from the AWD Astro van parts bin, and later used in the Bravada..
4r5Ie0qaFBOIPn2DkGYWaFpUUlhjcu3DEJkGirkkRV17ASMLpKWGZp0wmcZORTSM
