rustybugkiller
rustybugkiller Dork
4/30/22 4:17 p.m.
Every time I grab my grease gun, I have to spend a half hour figuring out why it will not work. I'll get a couple fittings greased and then nothing. Plenty of grease but for some reason it looses its prime.
Does a trouble free grease gun exist?
Help this grease monkey get grease.
4/30/22 5:21 p.m.
Air bubbles. You are trying to compress air instead of grease. Modern grease tubes are notorious for air bubbles.
I  drill a very small hole in the head where it threads into the body about halfway down the threaded area. Back off the tube just till it kisses the hole and a little blob of grease comes out,  then quickly tighten it back up.
Mr_Asa
Mr_Asa PowerDork
4/30/22 10:02 p.m.
On top of air bubbles, you could have fittings that are blocked by dirt and crap.
Purple Frog (Forum Supporter)
Purple Frog (Forum Supporter) HalfDork
4/30/22 10:28 p.m.
Many good guns have a bleeder screw at the top to bleed the air out.
bearmtnmartin (Forum Supporter)
bearmtnmartin (Forum Supporter) UltraDork
5/1/22 2:19 a.m.
Having run thousands of cartridges through hundreds of guns, here is what I do: pull the plunger, drop the cartridge in, and thread the head on just enough to keep it attached. Then release the plunger, and then tighten the head up. Unless its a garbage Chinese gun that will always do the job. No priming necessary because all the air is forced out through the loose threads.
rustybugkiller
rustybugkiller Dork
5/1/22 9:15 a.m.
In reply to bearmtnmartin (Forum Supporter) :
What is a good brand of grease gun?
Karacticus
Karacticus SuperDork
5/1/22 9:19 a.m.
Though I don't use it enough to justify the cost, this is the closest I've found to a no mess grease gun.
Lube-Shuttle
APEowner
APEowner SuperDork
5/1/22 11:32 a.m.
You might want to store it upside down so it doesn't lose its prime.
5/1/22 11:38 a.m.
In reply to rustybugkiller :
I usually buy or have used Lincolns. They are the ones in the tool box of pretty much every machine I am asked to run. I ran excavators for a year and a half during covid and they bought me one from Walmart which I threw away, and then they gave the whole fleet Milwaukee electrics which were awesome. But too pricey for just having around the shop for the occasional lawnmower service.
QWt2tfwdejVTa0Kiwv3Fq4cW8zZKRtHz6nh4VXWMkUVnXbHJ94cRPl75Jfrzu1Us
