Why is it so damned hard to find a nice, light, 17x9" wheel that will fit a 3rd generation Camaro that does not cost an arm or a leg?
Really, I just want to drive it on the street and autocross the big pig.
AquaHusky
AquaHusky New Reader
11/27/10 5:43 p.m.
Because people who want them bad enough will pay what they are told to regardless?
Nitroracer
Nitroracer Dork
11/27/10 6:08 p.m.
If the camaro had a more common bolt pattern like 5x4.5 it wouldn't be a problem. The low offset and chevy only bolt pattern make it a pain to find a nice modern wheel at a good price.
Javelin
Javelin SuperDork
11/27/10 6:23 p.m.
Aren't C5 Corvette wheels 17x9? The OE's are pretty light, it's the aftermarket knock-offs that weigh a ton.
patgizz
patgizz SuperDork
11/27/10 9:26 p.m.
4th gen ss wheels with spacers?
no problem finding nice wheels in 5x4.75, every rwd gm that wasnt a fullsize truck or the latest fullsize cars had it since like 1949. wheels are everywhere.
you could go the bmw wheel route too.
I would prefer to do this without adapters as well. C4 wheels may work but I don't think the C5 wheels will.
patgizz
patgizz SuperDork
11/27/10 9:41 p.m.
c4 wheels are same huge backspace as c5. the early ones were not but they were 16x9 i think.
if you wind up wanting c4 sawblades in 17x9.5 i'll hook you up cheap
I found these in 17x8 5x120 +15mm which will work IF they fit the hub center and spindle nut cover...
patgizz wrote: c4 wheels are same huge backspace as c5. the early ones were not but they were 16x9 i think. if you wind up wanting c4 sawblades in 17x9.5 i'll hook you up cheap
I need between a 4.5" and 5.2" backside setting. The vettes are all over 6.5"...
Winston
Winston Reader
11/28/10 10:36 a.m.
Why is it so damned hard for people to type an informative post title, so that I don't waste my time clicking on topics I don't give a E36 M3 about (like this one)?
porksboy
porksboy SuperDork
11/28/10 11:24 a.m.
Winston wrote: Why is it so damned hard for people to type an informative post title, so that I don't waste my time clicking on topics I don't give a E36 M3 about (like this one)?
Lighten up Francis. Read posts you may not be totaly interested in and you will learn more.
Ranger50
Ranger50 Reader
11/28/10 11:54 a.m.
+1, even if it is about a mulletmobile.
Brian
mtn
mtn SuperDork
11/28/10 12:03 p.m.
Be nice now. Dwayne Elizondo Mountain Dew Herbert Camacho is a relatively new member, he doesn't know how things work around here.
Appleseed SuperDork
11/28/10 12:49 p.m.
ncjay
ncjay Reader
11/28/10 4:48 p.m.
Nice, light, 17" X 9" wheel, and cheap? You can have 3 out of 4, but not all 4 without spending a bit of cash. Light generally equals weak. Those cars are a bit on the heavy side. I'd want something a touch on the heavy duty end of things. It really sucks when the center of the rim breaks off during a run.
Is there a place I can run my post count up so I can be more... you know... accepted?
patgizz
patgizz SuperDork
11/28/10 9:44 p.m.
how about strong, fit and cheap in a cragar soft 8?
turbojunker
turbojunker HalfDork
11/28/10 10:36 p.m.
patgizz wrote: how about strong, fit and cheap in a cragar soft 8?
My friend has them on his IROC
Wally
Wally SuperDork
11/28/10 11:52 p.m.
Whore (+1)
I am thinking more like this:
From CARS
pres589
pres589 HalfDork
11/29/10 11:07 p.m.
In reply to patgizz:
http://www.cragar.com/ProductView.aspx?id=1170&bq=%3Fc%...&AspxAutoDetectCookieSupport=1
If Dwayne cares about weight like he says he does, the Soft 8 is out.
neon4891
neon4891 SuperDork
11/29/10 11:50 p.m.
Dwayne Elizondo Mountain Dew Herbert Camacho wrote: I am thinking more like this: From CARS
Make that gold on a Pontiac, and Oh Dear God Yes.
Wally
Wally SuperDork
11/30/10 12:43 a.m.
pres589 wrote: In reply to patgizz: http://www.cragar.com/ProductView.aspx?id=1170&bq=%3Fc%...&AspxAutoDetectCookieSupport=1 If Dwayne cares about weight like he says he does, the Soft 8 is out.
Or lay off the between snack snacks
Trans_Maro
Trans_Maro Dork
11/30/10 1:13 a.m.
ncjay wrote: It really sucks when the center of the rim breaks off during a run.
Yeah, because that happens a lot
In reply to Dwayne Elizondo Mountain Dew Herbert Camacho:
Isn't there a larger selection of race rubber in smaller sizes?
Could you go with a 15" or 16" that is more common, or are you dead-set on the look of 17" wheels.
The folks at Diamond make some pretty light (for a steel wheel) options if you get into non-DOT stuff.
Shawn
If I run RACE rubber (or R compounds) I will get a set of 15s or 1s but I would prefer a set of nice tight 17s for street duty. The 17s I have listed above are where I will go if the hub bore is close to working. I have emailed the manufacturer for dimensional specs of the hub bore through to the center cap JIC.
pCm045uf9zMQx4Kws7fbkruq3vFkcsQqgv4Uv7fjkglU6cqZrti2W0owSlp6vv79
