Bobzilla
Bobzilla PowerDork
6/12/14 2:15 p.m.
Yes, for $300 for a set of pads. That's a bit above what I had in mind.
Looks like I'll just be buying yellow's this fall.
series8217
series8217 Reader
6/12/14 2:18 p.m.
Oh yeah, they even list pads for that application already, so you don't have to send them templates.
Even though they only list the R4-S you can still order them in other compounds if you call them.
By the way if you have a NASA membership you get 20% off. It pays off your NASA membership very quickly. The only way to get this discount is to call in your order, and make sure you ask for it.
Bobzilla
Bobzilla PowerDork
6/12/14 2:19 p.m.
Not a NASA member.
Sent an email to PF.
series8217
series8217 Reader
6/12/14 2:19 p.m.
Ah, I missed the pricing requirement.
You're very lucky that you have any performance choices in that price range!
Swank Force One
Swank Force One MegaDork
6/12/14 2:21 p.m.
series8217 wrote: Ah, I missed the pricing requirement. You're very lucky that you have any performance choices in that price range!
That's what I'M sayin'.
bravenrace
bravenrace MegaDork
6/12/14 2:25 p.m.
Bobzilla wrote: Yes, for $300 for a set of pads. That's a bit above what I had in mind. Looks like I'll just be buying yellow's this fall.
Where did you get that pricing? I see $149.95 for the fronts and $69.95 for the rears. And something else is that after I bought my first pair from them, every time I've bought pads from them since they have given me substantial discounts over their listed prices.
Bobzilla
Bobzilla PowerDork
6/12/14 2:28 p.m.
Just rechecked the Porterfield site. They have the wrong pads listed for the front of the Forte. Switch to the Elantra Touring and it shows the correct ones. $170 for pads frt and rr. Add another$85 for rotors and we're sitting at $255 for pads/rotors. That's not as bad as I thought.
Bobzilla
Bobzilla PowerDork
6/12/14 2:29 p.m.
In reply to bravenrace:
I mixed the porterfields up with the Carbotechs.
AngryCorvair
AngryCorvair UltimaDork
6/12/14 3:04 p.m.
my 2013 FMSI (Friction Materials Standards Institute) catalog shows for 2010 Kia Forte Front = D1397 and rear = D1398. The catalog shows that the D1157 was last used on the Rio and Rio5 in 2007. The FMSI drawing for D1398 says "similar to D1157 except indents for clip-on shim", so either one should work in your caliper.
google "brake pad FMSI D1397" (or D1398 or D1157) to see what's out there.
Bobzilla
Bobzilla PowerDork
6/12/14 3:12 p.m.
Yep.... been doing that.
Bobzilla
Bobzilla PowerDork
6/13/14 8:15 a.m.
welp... just got this back from Performance Friction:
Bob, Thanks for reaching out. Unfortunately we do not offer any pads in our line for Kia’s at this time. Regards, JC
Damn.
ebonyandivory
ebonyandivory Dork
6/13/14 8:29 a.m.
My first Google came up with this: http://m.autoanything.com/brakes/Kia/Forte/110A50530A0A0A14A10109A1.aspx
But I can't tell if it helps
Help here? http://www.forteforums.com/forums/performance-modifications/428-after-market-brake-pads-forte.html
Javelin
Javelin MegaDork
6/13/14 8:55 a.m.
PowerStop makes their Evolution Ceramic Plus for the Forte Bob. #171157 for the front and 171397 for the rears. They also make the Z16 kits, #KOE5387 for the fronts with OE rotors or #K5837 for the drilled/slotted version. Those are the brakes I used on the P71 and the Mazda5.
Bobzilla
Bobzilla PowerDork
6/13/14 9:34 a.m.
The OE Kia pads are a really good pad. If I was just wanting a stock replacement, I'd buy a new set. They have a nice initial bite and decent feel but don't handle heat well.
Javelin
Javelin MegaDork
6/13/14 9:37 a.m.
The Z16 is not a stock replacement pad, it's comparable to an HPS. I've run them on my autocross RX-7 and Miata. They did HPDE's in the P71 well, too.
SkinnyG
SkinnyG Dork
6/13/14 9:45 a.m.
Why not adapt some Wilwood calipers? Then at least you don't have to go through all this again when the new pads need replacing and you can't find a supplier. Yeah, it's more money, but pad options just open up at that point.
Bobzilla
Bobzilla PowerDork
6/13/14 9:51 a.m.
I'm not changing calipers on a car still under friggin warranty!
HiTempguy
HiTempguy UltraDork
6/13/14 11:15 a.m.
I think Porterfield is your best option. I also do not think they charge extra for custom pads last time I inquired.
Having said all that, you hate EBC yellows because of EBC reds on a Swift? I had EBC yellows on my 1994 jdm wrx, and let me tell you, besides the INSANE amounts of dust, they were the perfect daily driver/track day pad. No squealing, good braking, better fade resistance than a street pad. You should really try the yellows IMO.
EvanB
EvanB PowerDork
6/13/14 11:34 a.m.
SCCA members also get a discount on Porterfields.
Bobzilla
Bobzilla PowerDork
6/13/14 12:12 p.m.
EvanB wrote: SCCA members also get a discount on Porterfields.
well why didn't someone tell me! Geesh!
Bobzilla
Bobzilla PowerDork
6/18/14 7:22 a.m.
got an email back from Porterfield (I caught a mistake on their catalog). 20%off, makes a set of R4S pads $136 for front and rear. That is worth it.
g67QouP3zjtiFmxjd8qZC8Sv0IIa50nxav1fKOvebSf77yJWsTyCkEtPZkuqGR35
