Treb
Treb Reader
10/8/12 7:54 p.m.
So my 1976 Fiat 124 came with a clock in the dash. They break easily and are expensive to fix. The clocks, I mean...
Anyway, I put in an almost-matching Volvo clock from the eighties. It died, too.
So now I have 3 cannisters, 2 veglia gauge faces, 3 sets of clock hands... and I bought a clock from a 91 Mazda 929 off ebay to build a working clock with. The Mazda clock has a big housing, but the actual mechanism is tiny. (The housing and the adjuster mechanism will be under the dash, I think.)
So the Mazda clock has 4 wires. Power, ground, dash lights, and ???
Anybody have an idea, a diagram, or a good grasp of mazda wiring color codes (assuming there are such)?
Thanks for the help. Matt
4g63t
4g63t HalfDork
10/8/12 8:01 p.m.
Constant power ,switched power, ground, lights
pres589
pres589 SuperDork
10/8/12 8:52 p.m.
Why would a clock need switched power?
peter
peter HalfDork
10/8/12 9:13 p.m.
pres589 wrote: Why would a clock need switched power?
Illumination (thus also needing the lights wire).
Run_Away
Run_Away Reader
10/8/12 9:18 p.m.
If it didn't have switched power it would be constantly illuminated, and drain the battery (um assuming a digital clock).
pres589
pres589 SuperDork
10/8/12 9:27 p.m.
So what's the light lead doing? Ground is common between the motor and the light, the motor has constant power, the light gets its own varied 0-12VDC+, right?
turbojunker
turbojunker HalfDork
10/8/12 9:34 p.m.
If it's digital the light lead dims the numbers.
Treb
Treb Reader
10/8/12 9:47 p.m.
Not digital. So yeah, I'm wondering what switched power would do, too.
pres589
pres589 SuperDork
10/8/12 9:50 p.m.
I can't find a wiring schematic online in the two minutes I spent looking.
Treb
Treb Reader
10/8/12 9:54 p.m.
Original Fiat clock:
Volvo clock:
Mazda clock:
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
10/8/12 11:31 p.m.
Heh i have one of these clocks too... But now i want a volvo clock.
Treb
Treb Reader
10/9/12 9:39 p.m.
So I googled again for an answer to this question, and the first result... was this thread.
Impressive, Google. Not helpful, but impressive.
Any ideas?
Matt
92CelicaHalfTrac
10/9/12 9:43 p.m.
You're probably going to need to dig up the FSM. Might not be easy, there weren't a TON of these things out there.
I'll see what i can find tomorrow.
Treb
Treb Reader
10/9/12 9:50 p.m.
Thanks!
Treb
Treb Reader
10/11/12 5:25 p.m.
So, there are 4 wires into the clock: black, green, brown, and red.
Looking at the circuit board inside the case, where the wires are soldered on, there are some labels.
Black is labeled "GND", which is a good start.
Green is labeled "TNS." Tracing it on the circuit board, it appears to be a ground for the light socket, and possibly nothing else.
Brown is labeled "ILL" which I will hazard a guess stands for illumination, as that trace seems to head to the bulb socket on the circuit board. (I checked them as far as the socket with a voltage meter/continuity tester.)
The red wire is labeled "B"
B appears to connect to a resistor, which then leads... well, elsewhere on the board. My first guess would be B as 12v positive, unswitched, and leave TNS and ILL unattached, as I won't be using the light socket on the board.
Any warnings/better ideas, or reasons that the light would have its own ground?
Thanks
Matt
93gsxturbo
93gsxturbo Dork
10/11/12 5:56 p.m.
The light may have its own ground if its wired up like Autometer gauges. The light snaps into a plastic housing, cant ground though the plastic housing, and therefore needs its own ground.
The B+ and other ground are for the clock. Easy way to test, put an ohm meter across the suspected light leads, should read very close to 0 resistance. Pull the bulb out. Should read infinite resistance (open).
93gsxturbo
93gsxturbo Dork
10/11/12 5:57 p.m.
Have you looked at the Autometer clock options?
http://www.autometer.com/search_results.aspx?q=clock
Treb
Treb Reader
10/11/12 7:54 p.m.
I looked through the autometer things, and some of them might be close-ish.
But my wife took one of the fiat clocks to an alleged clock repair shop here in town, and he massacred it. So I already have a Fiat case, hands, and face, with the mechanism out. If that's not crying out to be an ill-advised, unnecessarily complex project, I don't know what is.
Matt
Birthdays
p6M0ntLs8pgMMeVg0b9vejX7zn08e2BF3D9lPIdgb9D7wOtnHs6EvgxZxdIXhCp5
