shawone
shawone
12/7/20 7:37 p.m.
Hi everyone, can anyone help me understand how this could have happened? The engine was recently rebuilt and was not driven long before we noticed it had started to smoke out the breather and had excessive blow by so we ran a compression test and number 4 was low, pulled it back down and found this, guess you can imagine how the bore looks, it's a 1300 Toyota engine.
12/7/20 7:44 p.m.
Are those full floating or press in wristpins?
shawone
shawone New Reader
12/7/20 8:15 p.m.
In reply to Pete. (l33t FS) :
Press in
Streetwiseguy
Streetwiseguy MegaDork
12/7/20 8:58 p.m.
  The small end of the rod is the wrong size, would be my guess.
Donebrokeit
Donebrokeit UltraDork
12/7/20 9:03 p.m.
Either the pins are worn or the pistons are worn, either way one of them is out by a thousandth or two.
bentwrench
bentwrench SuperDork
12/7/20 9:45 p.m.
Another thing that will push a pin out is a bent rod, wrist pin bushing not parallel to the crank.
TurnerX19
TurnerX19 SuperDork
12/7/20 9:46 p.m.
Press fit pins suck.
Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
12/7/20 11:39 p.m.
I like the bent rod theory.
Streetwiseguy
12/8/20 6:27 a.m.
One way or another, that rod is trouble.
shawone
shawone New Reader
12/8/20 10:17 a.m.
Afternoon guys, thank you all for your suggestions, would it be ok to reuse the piston with a new rod?
Streetwiseguy
12/8/20 10:47 a.m.
In reply to shawone :
I'd be nervous about that, just because we don't know how much odd stress has been put on it.  Is the wrist pin ok?  It is fit to the piston, so they need to replaced as a pair.
shawone
shawone New Reader
12/8/20 10:56 a.m.
Tbh I am not sure what is good, cause the pin did this to the bore
APEowner
APEowner Dork
12/8/20 11:09 a.m.
That's caused by the pin fit in the rod being too loose.  That can be an installation error, the pin being too small or the rod being too large.  The first and the last are the most common.  A bent rod can also cause that but it's less common.  Pistons and pins come as a set and that pin is shot so you'll need to replace both the piston and the pin.
That block will probably need to be sleeved.  It's unlikely that an available oversize bore will clean it up and when pins walk out like that they often distort the bore in addition to scoring it.  You'll need to see if there's additional damage caused by pumping wrist pin and cylinder filings through the engine but at a minimum you're looking at a rod, wrist pin, piston and cylinder sleeve.
It's worth noting that there's absolutely nothing wrong with a properly done cylinder sleeve and I've built many engines with one or more sleeves in them and never had an issue related to them.
wspohn
wspohn Dork
12/8/20 11:20 a.m.
Not necessarily.  Floating pins can have a circlip go walkabout with similar results (Teflon buttons can be the answer there).
I have built and raced on engines with press fit pins, and have had no problems as long as you have good pins and the small end of the rods is correctly sized for a press fit.  But the first rule of press fit rods is to never try to mate them with pistons at home - get a pro shop to do it for you.
shawone
shawone New Reader
12/8/20 11:40 a.m.
In reply to APEowner :
They could be additional damage. cause that score in the bore is fairly deep, so over bore is out of the question for sure.
Would got to either sleeve it or get a fresh block. Thanks
12/8/20 12:17 p.m.
You're not using that piston because that bore will have to be overbored.
If there's enough wall thickness, a machine shop might be able to offset the boring bar to mostly take metal out from that side. It all depends on how deep the gouges are, what the wall thickness is, and what oversize pistons are available.
shawone
shawone New Reader
12/8/20 1:14 p.m.
The gouges are deep, too deep for overbore I believe.
iceracer
iceracer MegaDork
12/8/20 1:39 p.m.
One oversize piston would cause a balance problem.
Sleeve or block.
Streetwiseguy
12/8/20 1:54 p.m.
Ouch.  Is there a used shortblock out there anywhere?
Peabody
Peabody UltimaDork
12/8/20 2:58 p.m.
Probably not but there's likely enough extra material on a piston that you you could even out the weight
12/8/20 4:10 p.m.
Yeah, the big three would have single-hole oversizes all the time.  The difference in piston weight is usually fairly low, and as you point out, that can be remedied.
I too think that probably can't be fixed without sleeving, which is fairly "traumatic" and may require reboring the cylinder next to it due to warpage.  But that is an eyeball guess, not very well calibrated of a guess.
hqGESptS5DeAHM2qGD5NILcTOUdDBFMbsWqFyFgiPgocILNXIbsp8SSzYaJZ4eNV
