iceracer
iceracer UltimaDork
1/22/18 2:15 p.m.
In reply to AngryCorvair :
That is why you should re-torque after a run.
iceracer
iceracer UltimaDork
1/22/18 2:17 p.m.
In reply to dculberson :
Oh, but they use Torque Sticks.    Been through that.
The point I guess , like any tool, they have to be used properly.
The service manager was dumfounded when he checked my lug nuts with a torque wrench and
found them way over torqued after a "Tech" had used a "proper" Torque Stick".
This was after a couple of complaints.
1/22/18 3:03 p.m.
If I don't torque my lugs before every session, I'm out there worrying about--and on those long turns, like T3 at Roebling--you have lots of time to worry.
Solution: You'll see me constantly torquing my lugs.
ProDarwin
ProDarwin PowerDork
1/22/18 3:04 p.m.
Only time I had a wheel come off was due to a collision.  Tore the hub right out of the bearing.  Brake rotor was still there too, minus a caliper-shaped chunk of it.
Casual Six
Casual Six UltraDork
1/22/18 6:41 p.m.
A bit pothole hit did something like this to my old Crown Vic in a construction zone on the QEW. I thought the vibration was just from the really bad road surface. A couple kilometres later, and the road smoothed out as the vibration got worse. Just as I was coasting to a stop on the shoulder of an exit ramp, wham! The right rear wheel was no longer attached to the car.
fasted58
fasted58 MegaDork
1/22/18 6:58 p.m.
ain't nuttin' new
freetors
freetors New Reader
1/22/18 7:13 p.m.
But don't torque your lugnuts while they're still hot unless you want them to be overtightened and possibly stretch.
Ottawa
Ottawa New Reader
1/22/18 7:18 p.m.
MotorsportsGordon said:
David S. Wallens said:
Some rather exciting footage from our friend Christina's recent Sebring outing:
Good wheels,but certainly not great wheels.
Not sure how many people got that reference...
frenchyd
frenchyd Dork
1/22/18 7:23 p.m.
I raced my Jaguar with wire wheels for decades.  Wonder how much torque that brass hammer of mine had, anyway?
jimbbski
jimbbski Dork
1/22/18 7:23 p.m.
I had this happen to me twice while racing on track. The first time it was due to the stress of the rear suspension bottoming upon landing after going over a hill. It was A FWD car and the stub axle broke allowing the whole wheel/brake assemble to part company with the car. Due to a fellow racer having the same kind of car I was able to replace the whole rear axle and race the next day.
The other was on a different race car, it was caused by me not re-torquing the rear lug nuts. During the race one set of nuts loosened up enough to cause total failure of all 5 studs.  I thought the wheel vibration was a flat spotted tire.
irish44j
irish44j UltimaDork
1/22/18 8:08 p.m.
Knurled. said:
In reply to irish44j :
I have seen wheel studs shear off several times.  Usually it is only one, after the other three/four lug nuts fell off.  Never all four/five.
In any kind of motorsports, EVERYTHING is a maintenance item on a long enough timeline, tho!
Yeah, that's basically what I was saying..I've seen one break, but if ALL of them break, it usually means the pit crew didn't torque things correctly....
1/22/18 8:56 p.m.
It's a true classic.
MUBBzRsSO6v775CHj1SYlX3GddTM6FTk6khm37tHm3DfsrhxZWZps3Ro7pT0AdTn
