Lennyseleven
Lennyseleven Reader
7/29/09 9:27 a.m.
Ive got a 73 Honda CL125 and the throttle return doesnt work, Im just wondering if this part is at the handle or in the carb?
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
7/29/09 9:29 a.m.
I've seen some bikes were it's just the friction between the grips and the brake lever that cause the throttle to stick.
xci_ed6
xci_ed6 Reader
7/29/09 9:44 a.m.
Could also be the cables.
Woody
Woody SuperDork
7/29/09 9:47 a.m.
On my 71 Honda Mini Trail, there is no throttle return spring. You need to manually close the throttle. Kind of like early cruise control.
44Dwarf
44Dwarf Reader
7/29/09 10:25 a.m.
Well theres loads of parts it could be...
Key parts are. Carb slide it self and the anti rotation groove. Slide spring weak or missing. Cable dry or fraid can be inside the cable housing near tight bends etc. Grip pushed on to far rubbing the horn button housing and or rubbing end of handle bar. End of handle bar mashed from a fall. Dirt / mud / crud build up between handle bar and throttle sleave. (due to riding with torn grips)
7) combo of any the above.
44
Rusnak_322
Rusnak_322 New Reader
7/29/09 1:06 p.m.
I would take the cables off, see if the throttle slides smoothly and see if the carb slide closes. If they do, it is the cable. (I assume that a bike that old is not running a push/pull throttle with two cables).
44Dwarf
44Dwarf Reader
7/29/09 1:14 p.m.
CL125 has just one cable and runs a VM carb i belive.
XTiuceIC80CELIwEnaSTWSgFyhpsd98fnjTcUyAXnq52VWhOFvbQ4vnb86fLEZcL
