Any Toyota guys in here?
I have a '86 SR5 truck with the 22re and 5 speed. It really needs some upgraded braking power.It is an IFS truck. No solid axle yet
Iv been trying to find some solid info on what parts I can use to upgrade my brake system. I know enough about brakes to know the parts need to compliment each other to get a decent system.
I did some reading on Pirate 4x4 and Yota Tech but I could not find any threads with solid confirmed info in what parts to use together.
Right now I am thinking to get this stuff.
-'97 T100 dual diaphragm brake booster
-'95 4Runner 1" MC
-'95 4 pot 4Runner brake calipers
-Stainless brake lines
-EBC Green Stuff 6000 SUV and light truck pads
Recommendations, ideas, opinions are welcome.
Thanks guys
My only suggestion is to try and find a complete system that will swap over as a unit from the booster to the caliper. There is a lot of math involved with master bore and stroke vs caliper piston size that goes into getting the right psi at the pad. Mixing and matching is great if you can do that math.... If you can't your better off buying a system where it was done for you. Pirate had a great thread on this so do a google search for brake system design and look for the pirate thread.
That being said, perhaps the easiest start is a rotor that is bigger by an inch or so. If the piston size is the same in the new caliper the increased radius of the rotor gives you mechanical advantage with no hydraulic system changes.
I know some cars use older Toyota truck brakes as an upgrade(is, 240z guys use the bigger Toyota calipers as a poor man's big brake kit), so you probably have a solid starting point. I don't know the specifics, but my guess would be that a slightly newer Toyota caliper and rotor w/ the proper master cylinder would be a simple junkyard upgrade.
Love your truck by the way!
That truck shoudl have big 4 piston front calipers. Is there something wrong? I'd try some good pads first and refurb the system.
Look for the 1985 and 1986 turbo trucks. They were absolute animals and came in the form of the truck and the 4 runner. They came with 4 piston Nissin brakes and a ton of other goodies including rowdy differentials among others.
Enjoy...
I was going to say the same thing as Seth and Caffine.
I'd start with a good service (bleed the fluid, check pad/disc life, look for leaks, etc). If no issues are found and you still think you need uprated brakes after you do a thorough bleed, then I hear positive reviews from people with dual diaphragm boosters but can't help but think:
I was going to show you some quick "brake math" and came across this guy's site. It seems he's tried a bunch of different combinations of junkyard toyota and GM parts and has a pretty good writeup of the results.
http://home.4x4wire.com/erik/4runner/brakes/
It seems your current bore is about .8125", you have 4-piston calipers with 2-pistons measuring 1.335" and 2-pistons measuring 1.685, I'll assume your pedal ratio is 4:1, and I have no idea what your booster's advantage is going to be (a 7" diaphragm at 8psi of vac produces 307.72lbs of output force) .
It seems that later Toyotas had 4-piston calipers with 1.685"dia pistons, and a pedal with a higher ratio.
100lbs of pedal force becomes 400lbs of force after the mechanical advantage.
pedal force + booster assistance becomes 707.72lbs
pir squared MC piston diameter = .581in squared.
1000lbs of force divided by .581 = 1218.1psi
pi*r squared the piston diameter multiplied by the number of pistons in the calipers = 3.63 in^2
1218.1psi / 3.63 in squared = 335.57lbs of braking force.
If my math is correct, then it tells us that:
If you increase the diaphragm advantage then you increase clamping force at the calipers (but decrease pedal feel).
You can gain clamping force at the calipers by increasing your pedal ratio
If you increase caliper piston surface area (say to a later Toyota 4-puck that has 1.685" pistons) then you REDUCE the clamping force (1218.1psi / 4.46 in squared = 273.12 lbs of braking force).
If you decrease master cylinder size then you are going to INCREASE port pressure but move less fluid.
If you increase master cylinder size then you are going to DECREASE port pressure but move more fluid.
Years ago, when I read this book they mentioned that most brake upgrades aren't done to gain clamping force, but to increase surface area and reduce fade.
Good times. I'd really like to know what you find, and how it works for you (I have an '87)
