petegossett
petegossett PowerDork
5/30/14 8:43 a.m.
Ok, next question - how do I determine what engine this has, and whether I need to worry about changing a timing belt?
From my best Google-foo and reading the owners manual, I think all '99 US Vitara received the 2.0 DOHC, which I think has a timing chain. Does that sound correct???
5/30/14 1:04 p.m.
Pete, get cozy with some of the Suzuki forums.
http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/34687-all-tracker-vitara-2-0l-engines.html
This one's specifically for off-roaders.
http://www.zukiworld.com/forum/
petegossett
5/31/14 6:28 a.m.
In reply to 914Driver:
That link on the Suzuki forums was one that left me even more confused! But I think I figured it out by using the Napa website. According to their vin decoder, my '99 Vitara is a 2.0L and has a timing chain. Not saying they're 100% correct, but I figure they're 90%+.
petegossett
5/31/14 3:21 p.m.
Just got back from a ~65-mile round-trip maiden voyage to band practice. As I was leaving town, it crossed my mind that this might be the first time it's reached 55mph in 1-years. I've pretty much confirmed that to be true now. No problems to report, the brakes seemed to be dragging a bit on the way there, but they were much better on the way home.
oldopelguy
oldopelguy SuperDork
5/31/14 5:23 p.m.
My '95 is all stock and unstoppable in the snow. Cheap set of Winterforce tires and it will go anywhere.
I have an aftermarket hard top, which really helps keep the heat in. We picked it up from a salvage yard we found through car-part.com. It took a day trip to drive to middle of nowhere WI to get it, but for a $500 hard top it was worth the drive.
Billy_Bottle_Caps
Billy_Bottle_Caps Dork
6/2/14 4:24 p.m.
In reply to petegossett:
It has a chain. Also check out zuharrie website good tech. Another vote for low range off-road
Toyman01
Toyman01 UltimaDork
6/2/14 6:28 p.m.
Toyman01 wrote: In all honesty, I'm been looking for a 4 door one to leave mostly stock. A decent set of tires, a winch and some brains will get you most places you need to go. blockquote
Look what I found, and just might be picking up tomorrow.
No super cool flames and needs a head gasket at minimum. The price is right though.
petegossett
6/2/14 7:41 p.m.
Nice!
My in-laws have a tin-top 4-door Tracker the same vintage as mine. It sat unused all winter because they couldn't figure out that the key-fob clickers in the glove box were for an aftermarket alarm.
I'd tried to buy it from them, but because they paid $5k for it 2 years ago they wouldn't even come down to book value.
petegossett
6/9/14 5:41 a.m.
Finally got a bit of garage time with it last night. Got the top replaced in about 2-hours, it went super easy. I also checked front & rear diff fluids and was glad to discover that despite the wet rear diff housing, fluid began dribbling out the fill hole so no worries there!
Next question - I'd planned on refilling both diffs based on the fact it has 91kmi and a completely unknown service history, but the fluid in both diffs was clear and smelled like new fluid. Should I go ahead and refill them anyway out of principle or leave it be since it seems ok?
Toyman01
Toyman01 UltimaDork
6/9/14 6:35 a.m.
I don't change mine unless the fluid is black or I am working on the axle.
petegossett
6/9/14 9:20 a.m.
In reply to Toyman01:
Thanks, that was my gut feeling too.
petegossett
6/9/14 1:02 p.m.
Next question: Trans fluid/filter - to change or not?
It's not the worst looking fluid I've seen, but certainly not new. I do notice it lurching when it shifts up into 2nd, even in low speed/low load situations. It's even worse if I try to accelerate quickly and/or don't drive smoothly.
Let sleeping dogs lie, or flush/fill/filter before bad things happen?
Kenny_McCormic
Kenny_McCormic UberDork
6/9/14 1:59 p.m.
Changing the fluid on a automatic trans won't hurt it unless it's already dead.
Bobzilla
Bobzilla PowerDork
6/9/14 2:17 p.m.
Drain and fill with new filter. I never recommend a flush on anything over 5 years old or 50k.
petegossett
6/9/14 5:34 p.m.
Ok thanks, that'll be next on the list!
L2asP8cVkXmfSVcf0glZd2ruFJG6YlOL32wV3UOxjXKCfp4VjYFQNK5ajSJNLZYg
