Hi there,
I found this site after googling "burnt transmission oil" and found the minds responding to be very bright and generous, so kindly chime in if you could be helpful.
Here is what is happening. I live in LA, though I am in New Zealand at the moment, and my friend has my car in LA. I purchased the car 4 months ago from my trustworthy landlord, who had had the car since is was brand new. Before I purchased the car, I took it to my mechanic to look over to see if there were any issues or if he felt the car was a good buy. He came up with a about $500 worth of little things like burnt trans oil, dirty oil pan, spark plugs and the like, but he felt the car was pretty solid. I purchased the car for $5700. Two weeks ago, I did most of the suggested, including replacing the burnt trans oil, oil pan, spark plugs...
My friends sent me an email a couple of days ago saying the car was slipping, then struggling a bit with acceleration. She dropped it off at my regular mechanic to run a diagnostic. They arrived at code p0755 suggesting transmission problems. They said my car was still under warrant since (96 months or 80K). My car has 75 K on the clock. My friend dropped off my car at Toyota and below is the email they sent me with the proposed path moving forward.
"Hi As per our pone conversation here are the recommendation and finding for the 01 Rav 4
check engine light on code p0755 harsh shifting to repair we will need a ECM reolaced to setart with est $ 1040.00 if trans is still shifting harsh will also need to get a TRANS est $3485.00 other idems that the tech found was oil leaking from valve cover gasket.timing cover,crank seal ,reseal valve stem seal ,spark plugs, est $ 2899.00 ADJUST REAR BRAKES EST $ 48.00 CABIN AIR FILTER EST $ 70.00 THANK YOU TONI KUBINSKI"
When I asked about the warranty, he said this.
THE REASON IT IS OUT OF WARRANTY IS DO TO TIME NOT MILES. AS FAR AS THE TRANS WE WILL NOT KNOW TILL AFTER THE ECM IS REPLACED AND IT COULD BE SOME TIME BEFOR YOU CAN TELL. YOU ARE MORE THE WELCOME TO CALL TOYOTA AND SEE IF THY CAN HELP ,1-800-331-4331 I WOULD BE MORE THEN HAPPY TO HELP YOU AS MUCH AS I CAN TONI
My mechanic is pretty confident the car needs a new transmission given the burnt trans oil history and said if we cannot get Toyota to cover it under a warranty, he can do it for $1700 - $2000 and forgo replacing the ECM. My mechanic and I both smelt a rat when with some of the other findings. I mean, the spark plugs in the car are only two weeks old. Why would they suggest replacing?
I would love your expert notes on what you suggest I should do. How can I confirm that this is still under warranty because I am no longer in the time frame but am still under the mile requirement?
I also want to know that if the transmission is going at such a low mileage, does this mean I have a lemon and should expect other things to go in the future?
Thanks a bunch - I look forward to your responses.
Best - Mary-Lyn
