Conquest351
Conquest351 UltraDork
11/27/13 2:34 p.m.
I need some measurements from a 2003+ Crown Vic rear axle.
  • Hub center to hub center
  • Brake rotor hat to brake rotor hat
  • Length of upper and lower control arms from bolt center to bolt center
  • Length of both Watts Link arms
  • Height of the upper and lower control arm bracket from bolt center to bolt center
  • Distance from lower shock mount to lower shock mount bolt centers
If someone can get me those, you'd be my new best friend on teh interwebs and I will give you a hug if we ever meet in person.
fanfoy
fanfoy HalfDork
11/27/13 4:17 p.m.
This is freaky, because I wanted to start a thread asking for those exact dimensions on a 2003+ P71 rear axle
So if someone can get those, they'll have another new BFI (best friend on the interweb). No sure about the hugging part
Conquest351
11/27/13 4:31 p.m.
I have all the dimensions for a 2000 (since I own one) but I saw somewhere that the shock mounts were moved outside the frame and the axle itself got longer and thus has shallower offset wheels to make up the difference? Something to do with the fact the front suspension got changed so they had to mess with the ass end as well to keep it all square.
Conquest351
11/27/13 4:45 p.m.
From my 2000:
  • Hub center to hub center - 67.25"
  • Brake rotor hat to brake rotor hat - 66.75"
  • Length of upper and lower control arms from bolt center to bolt center - Upper = 11" Lower = 18.5
  • Length of both Watts Link arms - 22" each
  • Height of the upper and lower control arm bracket from bolt center to bolt center - Whole bracket is 9" top to bottom, bolt centers are probably 8" apart.
  • Distance from lower shock mount to lower shock mount bolt centers - Right at 39"
Axle tubes are 3" in diameter near the outside and slide into a 4" diameter flange on the differential. Differential is 12" from top to bottom. Differential cover sticks out 3".
If the 2003+ has a 2 piece driveshaft, I need the length of each driveshaft from yolk center to yolk center.
fanfoy
fanfoy HalfDork
11/27/13 9:08 p.m.
Thanks for the dimensions conquest351. If we keep bringing this on top, someone should answer the call?
Maybe it should be on the GRM portion of the board?
11/27/13 9:13 p.m.
Sure, to help it get more eyeballs, I'll move it to the main GRM forum. If you'd rather have it moved back to Off Topic, just say so.
Conquest351
11/27/13 10:40 p.m.
Nah, it's good here. I'm way too used to posting in Off Topic LOL. Thanks!!
Conquest351
11/29/13 9:59 a.m.
Bump for more views. Anyone?
Coldsnap
Coldsnap Reader
11/29/13 2:52 p.m.
i'll crawl under mine tonight
Conquest351
11/29/13 3:17 p.m.
Coldsnap wrote: i'll crawl under mine tonight
Love you!
fanfoy
fanfoy HalfDork
11/29/13 3:19 p.m.
Love you more.
Conquest351
11/29/13 3:29 p.m.
One more thing, I need the offset of the pumpkin. That is, the measurements of the axle tubes to see how far off to one side it is. That would be super.
Coldsnap
Coldsnap Reader
11/29/13 7:00 p.m.
Ha, I can't fit under my Vic. Too much weightlifting I guess. Wish I took my jack stands with me when I moved.
fanfoy
fanfoy HalfDork
11/30/13 1:42 p.m.
Let's put this back on top. Someone's got to be able to help.
Conquest351
11/30/13 3:09 p.m.
Coldsnap wrote: Ha, I can't fit under my Vic. Too much weightlifting I guess. Wish I took my jack stands with me when I moved.
If you don't do your own oil changes, can you possibly get the measurements next time you take to have it done?
Hntsvl_E30
Hntsvl_E30 New Reader
12/1/13 9:14 a.m.
I'm changing my watts link stud today on the '09. Let me check
Hub center to hub center - 67.5"
Brake rotor hat to brake rotor hat - 70.75"
Length of upper and lower control arms from bolt center to bolt center - 11" upper, 18.375" lower
Length of both Watts Link arms - D.S. 21.5", P.S. 22"
Height of the upper and lower control arm bracket from bolt center to bolt center - 8"
Distance from lower shock mount to lower shock mount bolt centers - I had to measure center of shock bracket to center of shock bracket - 53" since the bolts come through transversely.
Conquest351
12/2/13 11:26 a.m.
In reply to Hntsvl_E30:
You, sir, are awesome. Give yourself a hug from me. Better yet, get a large chested woman to do it for me. Yeah.
fanfoy
fanfoy HalfDork
12/2/13 11:30 a.m.
Thanks man! Much appreciated.
Hntsvl_E30
12/2/13 12:57 p.m.
You are welcome. What are your plans with that info? Custom hung rear? IRS?
Conquest351
12/2/13 2:38 p.m.
Well, it's to use the Crown Vic rear end in a custom car. Figured since they're super available and all the police departments are retiring them, you can find them everywhere. Did you happen to get he offset of the pumpkin? Difference in lengths of the axle tubes?
7qwRB83INLTO5eBxwarZ2Z7jHgjhtM2xyN7mHj7YOPIqVVchRFHML7td0wpr2joo
