DrBoost
UltimaDork
4/2/15 5:05 p.m.
Ok, so my 3D printer kit has been up and printing for about 5 days now. I promised feedback and general info. Check out the build thread in the link for the build process. Here goes.
To start printing stuff you need:
a printer
Slicing software
You may also want:
3D modeling software like Google Sketchup or Blender
Printer interface software like Pronterface
You'll also need:
Stuff to print. You can download pre-made stuff at places like Thingiverse and quite a few others.
You take the file you made or downloaded and run it through your slicer software. That program slices the file into layers to the set layer height you've chosen. This then becomes the G-code, the file that your printer uses to actually print.
The biggest learning curve for me was the slicer software. I started using slic3r, the kleenex of slicer programs. I wasn't able to get very good prints. I started printing Lego bricks. I figure that they'd be great calibration pieces since they actually have to be pretty precise. They did indeed lock together, but the walls were very thin. Slic3r also printed what's called a raft. It's basically a plastic platform for the printer to print the part on. "The raft just snaps off" I was told. I never got a raft to snap off. I actually spent almost an hour on each lego piece sanding the raft off. Slic3r either can't print without a raft, or they've hidden that feature. I decided to try another slicer program; kisslicer (keep it simple slicer). It's anything but simple, you can change EVERY setting you can think of. So, I watched a few tutorials and posted on a forum and got things set up.
I had already printed a light switch using slic3r and it was unusable for two reasons, the dreaded raft, and the fact that the print quality was craptasitacal. Here's the back of the light switch, showing the crappy print quality.
You can see lines that aren't straight, the fact that the rear and sides aren't connected around most of the perimeter.
I took that same 3D file, ran it through kisslicer, using the same settings I used with slic3r and came up with this
New here's a picture of them both, side-by-side
So, for me, assembling the kit was fairly easy, Colin at MakerFarm (where I purchased my kit) has simply phenomenal customer support. There are all kinds of cool things to print, and you can design your own stuff. And I did.
My toilet is not like most toilets, it has a pressure tank in the tank that pushes water down the bowl with such force, if you're sitting down when you flush, your lower intestine will come out a little bit. Anyway, When we moved into the house, there were these thin plastic strips that held down the flush rod. One was cracked. So, years ago I made two metal straps. The paint wore off the straps and I got bi-metal corrosion. Not good.
So, I removed the two straps, measured them up and created plastic blocks in sketchup. I printed them, one set with slic3r and one with kisslicer. Again, the difference was pronounced. The ones with slic3r weren't as dimensionally accurate and were kinda sloppy. The ones with k-slicer were within a tenth of a millimeter at worst. Anyway, here they are, bad parts and new parts.
And installed
A replacement pressure tank would have been almost $400, a new toilet is a few hundred and a pain to install. I consider this a win.
DrBoost
UltimaDork
4/2/15 5:10 p.m.
Here's a few miscellaneous shots of the printing process, and a few prints I think.
Here's the light switch I printed for my 8-year old Star Wars fan
A toilet part being printed
And the light switch on layer 5 or so The squiggly lines in the words and around the print are a support structure. The plate is being printed face-down so the recessed words and the 45* bevel would be an overhang. The support is printed with much less material, and much faster so it barely bonds with the part. It snapped off very easy.
I had a lot more pictures than that, I accidentally deleted them from my phone. Oops.
bgkast
UltraDork
4/2/15 5:55 p.m.
Pretty cool, but I was picturing the toilet parts as more complex. ![](/media/img/icons/smilies/crazy-18.png)
DrBoost
UltimaDork
4/2/15 6:13 p.m.
I'm glad they weren't. Printing simple things at first is nice. If there are any issues, it's easier to figure out if the problem lies with the hardware or software.
The toilet fix makes this more awesome!
84FSP
Reader
4/3/15 7:25 a.m.
Looking good sir. Does this model fuse resin powder or utilize resin filament? Looks like PLA resin to me but wasn't sure.
Stop making me want a 3d printer.
But really nice job on the parts.
DrBoost
UltimaDork
4/3/15 8:54 a.m.
It's a spool of PLA plastic filament. The plastic is fed into a heated extruder and through a nozzle.
I'm surprised and impressed that you knew it was PLA.
Awesome. I have two more steppers to wire up and my Prusa i3 will be ready to calibrate. It's a labor of love sometimes, what with the new kid. But soon...
Nice to see a fell 3D Printer enthusiast on here.
84FSP
HalfDork
4/3/15 9:41 a.m.
In reply to DrBoost:
Don't be too impressed - have made my living the last few years in engineering plastics...
Thats awesome. I want one of these so bad. I just cant justify a good reason for one.
DrBoost
UltimaDork
4/4/15 2:39 p.m.
Since you bumped it T.J., I'll add that I printed my daughter a bracelet last night. I love being able to simply make anything I want, anytime I want.
![](http://i303.photobucket.com/albums/nn144/tpospeshil/Misc/IMG_1508_zpsns1gnhoi.jpg)
Here's the painted, but not dry, light switch.
![](http://i303.photobucket.com/albums/nn144/tpospeshil/Misc/IMG_1505_zpsvymtxkow.jpg)
Any more on this? I am looking at getting a printer. This one is in the running but I am leaning heavily towards the Printrbot Simple Metal with the heated platform.
Appleseed wrote:
I hate you. So. Much.
+1. Gotta get me one of these.
DrBoost
UltimaDork
8/25/15 8:07 p.m.
I've been printing stuff for me and others. I've printed drone parts, parts to fix a recliner, man, I cant think of all the stuff. I'll post pics later.
There's a market for those switch plates. You should be selling them.
If he doesn't, I might. I just bought a Printrbot Simple Metal. Pretty much direct competition to this one. It will be here Friday
DrBoost
UltimaDork
8/26/15 3:03 a.m.
What would you pay, painted or unpainted?
Another question: if you were buying it, would you rather it LOOK like it was printed, or want it smoothed out?
DrBoost
UltimaDork
8/26/15 3:04 a.m.
What made you go with that printer specifically? Do you mind sharing price?
DrBoost
UltimaDork
8/26/15 7:05 a.m.
My son is a dino-geek. So here's a mounted T-Rex head made as a door pull.
![](http://i303.photobucket.com/albums/nn144/tpospeshil/Misc/trex head_zpsmmog5c5b.jpg)
Photobucket no workey. Here's a link
https://photos.google.com/search/tra/photo/AF1QipMU9Y-McgByFWki5-QU-NIZoNZ7ngq6KTnqSKR9
