benzbaron
benzbaron Reader
8/31/09 11:57 p.m.
I get a battery every 2-3 years whether or not I want it. I think the way my car is wired with all the factory wiring and the aftermarket radio plus the 60amp alternator results in dead batteries. I want to put the larger battery and alternator on for harsh climates just in case I get all the electrics working.
My bike is weird, I think the battery is dying so every 2-3months I charge it 24hours and it still works.
Strizzo
Strizzo SuperDork
9/1/09 12:07 a.m.
In reply to confuZion3:
my old roommate ran one of the lawn & garden batteries in his 626. if it'll crank over the ole f2, it'll work in a miata. you'll need the terminal adapters to hook it up to the L&G battery posts
bludroptop
bludroptop Dork
9/1/09 8:41 a.m.
I don't consider a battery a 'wear item' like tires. Yes, they have a finite lifespan, but unless abused - it should be reasonable to expect a battery to survive the warrantee period. That said, I think you have to know going in that the warrantee isn't worth much if you have a failure.
For what it is worth, just this summer my VW got it's third battery since new. It is a '92, so the first two batteries lasted a combined 17 years.
Josh
Josh HalfDork
9/1/09 8:55 a.m.
I have a lawnmower battery in the Miata. Same CCA rating as the stock battery, the only difference I could see was the posts. I paid $20 plus $6 for post adapters, instead of the $100 I was quoted for the standard Miata battery. No problems since April or so.
Bobzilla
Bobzilla HalfDork
9/1/09 9:38 a.m.
Different areas have different battery life. My B-I-L in Texas can get an easy 5-6 years. But they don't have sub zero temps and harsh winters. Here, 3-4 years is about the norm. Considering winter can be -20 and summer can be 100... and a little everything in between. How much a car is driven, the type od driving... deternining a life for a battery is less likley than figuring a real lifespan for new tires.
keethrax
keethrax New Reader
9/1/09 9:51 a.m.
Bobzilla wrote: Different areas have different battery life. My B-I-L in Texas can get an easy 5-6 years. But they don't have sub zero temps and harsh winters. Here, 3-4 years is about the norm.
Northern MN has been brutal on my batteries (no real shock there). While I can get 3+ years out of them, they usually get replaced @2 so I don't actually have to deal with them failing when I need them.
CrackMonkey
CrackMonkey HalfDork
9/1/09 10:17 a.m.
I seem to get 5+ years out of batteries in the Mid-Atlantic. 97 Miata with 130,000 miles is on it's second. The 2002 Volvo was on it's first when we traded it a few weeks ago at 99,000 miles. The 2006 Lexus is on it's second or third (bought the car used, not sure, just know it's not original).
walterj
walterj Dork
9/1/09 10:26 a.m.
My Tundra is officially on its 9th year with the same battery. I am amazed - considering I've accidentally deep-cycled it many times. I will replace it this fall before it gets cold but... part of me wants to see just how long it will go.
Wcti1T0K0xZU58cUUlDWvFPCGOF1Q2nIANqaftb3xavSA2td0yjrry4JnXF1YCqo
