ClemSparks
ClemSparks SuperDork
7/11/11 3:43 p.m.
Ok, so I'd be surprised if the majority of folks here did not have AT LEAST one of the red, blue, or black LED flashlights from Harbor Freight (HF) that take 3 AAA batteries and have the little black plunger switch at the end.
I started this thread to ask what type of material (plastic, I assume) I might use and where to buy it to make a set of navigation lights out of a couple of these (think red and green lights at the front of a boat) by cutting a small circle of red and/or green plastic to put in place of the lense or under the lense.
Kind of like the old green military flashlights used to have interchangeable, colored lenses.
Then I realized if I had a red lense, I could duct tape or rubber band these to the fender of a trailer that had no working lights. Not legal, but better than nothing, to be sure.
So...who (think Home improvement or Target type places) carries some colored plastic that I could put in there? Maybe a craft place would have it?
Anybody tried it?
This post is half question, half sharing an idea I think others might like.
Clem
pilotbraden
pilotbraden HalfDork
7/11/11 3:51 p.m.
I would try the red taillight repair tape from the autoparts store
ClemSparks
7/11/11 3:54 p.m.
Good idea for the red. I wonder about green. Maybe some of that wrapping paper plastic stuff? A wad of easter grass, lol?
These things are so damn bright I think there will have to be some significant tint to whatever is used.
Clem
joey48442
joey48442 SuperDork
7/11/11 3:58 p.m.
Colored saran wrap?
Joey
TRoglodyte
TRoglodyte HalfDork
7/11/11 4:10 p.m.
Look for plastic supply in the yellow pages ( think 4X8 sheets of lexan) Find address in daytime,ask to see scrap bin. If they give you a hard time suitup for a dumpster dive after dark.
Hocrest
Hocrest HalfDork
7/11/11 4:13 p.m.
The disposable tupperware type containers are available with different color lids. Buy some, use them to take lunch to work once or twice, then they'll be free filters.
Hocrest
Hocrest HalfDork
7/11/11 4:14 p.m.
Or a Mountain Dew/Sprite bottle??
Woody
Woody SuperDork
7/11/11 4:15 p.m.
I often have to whack my cheap flashlights to get them to go on. I can't imagine that they would stay lit very long strapped to the back of a trailer.
Mazdax605
Mazdax605 Dork
7/11/11 4:27 p.m.
I sold a pop up camper many years ago to guy who came south a few hours to pick it up. He showed up in a ratty Honda accord. Now the camper wasn't huge but probably more than I would feel comfortable with behind a ratty Accord. The guy proceeded to tell me the thing had the heavy duty trailering package. I called bullE36 M3.
He then proceeded to tape flashlights with taillight repair tape over the lenses to the sides of the camper facing backward. Now if it had the heavy duty trailering package wouldn't have the wiring for a you know trailer?
I have no idea if the guy made it back without getting pulled over,but he didn't seem to care. I got my money so no big deal I guess,but still shady.
Chris
ClemSparks
7/11/11 4:27 p.m.
Woody wrote: I often have to whack my cheap flashlights to get them to go on. I can't imagine that they would stay lit very long strapped to the back of a trailer.
Lol...have you SEEN how trailers ride? They'd be getting "whacked" constantly. Seems there's daylight under the tires like 10% of the time.
Now...I don't really know that it would be conducive to longevity...
Clem
Ojala
Ojala New Reader
7/11/11 4:30 p.m.
I have seen bunches of homemade trailers with HF flashlights screwed down to trailer fenders. They use plumbing strap to screw it down, color the lens with a sharpie, and run wires from the flashlight into a home made trailer plug/harness that was "custom" tapped into the tail lights.
e_pie
e_pie Reader
7/11/11 4:32 p.m.
Check an arts and crafts store, they are bound to have something you could use.
ClemSparks
7/11/11 4:37 p.m.
The main reason I'm interested in this, just FYI, is not for a trailer but for navigation lights on the front of a little boat that won't have or need a battery otherwise (pull start 6hp Johnson outboard).
but I do think it would be handy to have the stuff on hand to make instant taillights for when I have to pull a trailer without working lights. Actually...it'll probably enable me to NEVER fix trailer lights again ;).
Clem
mad_machine
mad_machine SuperDork
7/11/11 5:03 p.m.
find a theatrical supply house.. sheet of gel.. roughly 3 ft by 3ft will run you about 8 bucks.. and come in any colour imaginable
Rosco Lux.. I recomend #26 or #27 for the red
90 or #91 for the green
JoeyM
JoeyM SuperDork
7/11/11 5:31 p.m.
This may not be GRM, but advance autoparts sells sheets of rigid plastic in their taillight section. That takes care of the red, but not the green.
jrw1621
jrw1621 SuperDork
7/11/11 6:05 p.m.
$23
The biggest issue you would have with the HF lights is that you would need 4 of them, 2 per side because the navigation lights are required to be viewable from both the front and the side. 4 lights at $4 each would be $16 and then you still need some fabricating supplies.
I think the $23 would be cheaper and certainly easier.
The lights like these are legal for boats up to 26 ft.
http://www.amazon.com/Innovative-Lighting-560-1111-7-Battery-Navigation/dp/B000ZFTK42/ref=pd_sbs_sg_5
For $29 more you can get the proper stern light which meets the requirement of being viewable for 360 degrees. I comes on a 3 ft pole and the rules require that it must be the high enough to be seen unobstructed from all around the boat.
http://www.amazon.com/Innovative-Lighting-560-2113-7-Battery-Navigation/dp/B001BWC75W/ref=pd_sim_auto_1
xd
xd Reader
7/11/11 6:45 p.m.
Dr. Hess
Dr. Hess SuperDork
7/11/11 9:03 p.m.
As a side note to your red-right-return thread, I have found that the ground connection between the light circuit board and the anodized body gets intermittent. If your flashlight isn't working well, pull the batteries and with a small screwdriver, scratch along the spring wire to aluminum body junction down inside by the circuit board.
93gsxturbo
93gsxturbo HalfDork
7/11/11 9:36 p.m.
The best source for tinted plastic is translucent colored binders from an office supply store. All the colors of the rainbow, thin, cheap, and fairly "true" color when used with white light behind them. We used to use them all the time to change gauge cluster colors.
ClemSparks
7/12/11 7:56 a.m.
93gsxturbo wrote: The best source for tinted plastic is translucent colored binders from an office supply store. All the colors of the rainbow, thin, cheap, and fairly "true" color when used with white light behind them. We used to use them all the time to change gauge cluster colors.
Now that's what I'm talking about!
ClemSparks
7/12/11 7:58 a.m.
In reply to jrw1621:
Well...yeah. That would work. I'm aware of those but was kind of thinking about a homebrew solution. Admittedly, my way is more work, but it would be a fun project with the kids.
And those HF lights aren't $4 each. I don't pay more than $1.50 for them...and they're often free.
ultraclyde
ultraclyde HalfDork
7/12/11 8:49 a.m.
If you get really desparate, theater lighting "gels" ,the colored filters used on stage lighting, are available on ebay for kind of cheap. good intense color but not nearly as cheap as office depot binders.
mad_machine
7/12/11 8:58 a.m.
if you go for gel.. try to get some from Rosco. Gam Gels are dyed and will come off of the plastic with some chemicals.. unless that is a look you are after.
N Sperlo
N Sperlo HalfDork
7/12/11 9:05 a.m.
now thats an idea. Consider my afternoon filled
93gsxturbo
93gsxturbo HalfDork
7/12/11 12:19 p.m.
Thanks for the complements guys. There is a reason I get the big bucks.
LhccoJ6T5jNqDioxyTlH8fcwSznSnxWh6STXqMO9j9wrpliyJ1ws1ZXEj4cBP1ax
