slowride
slowride Reader
12/16/14 10:11 a.m.
I've been using the Mach 3 Turbo since it was introduced. Recently they redesigned them and (I think) started making them in Brazil or Venezuela. Since the redesign, I've had 3 out of 25 that felt dull after 1 shave. Considering the cost of these things, and the fact that I had no issues at all until this redesign, I've been looking for alternatives.
I've used a DE (old school) razor before, and I may go back to it, but I can't shave my head with it. Any suggestions?
DrBoost
DrBoost UltimaDork
12/16/14 10:26 a.m.
Why can't you shave your head with a DE?
Here's my thoughts. go back to DE since I've found that nothing compares to a DE, either price or quality of the shave. If you can't shave your head with a DE, use any of the disposable blades. I shaved my head for a few years and the hair is so much softer that a blade would last for months if I didn't have to shave my face.
Now cue the complaints about 'another shaving thread!?"
slowride
slowride Reader
12/16/14 10:30 a.m.
Too bumpy! I tried one of those HeadBlades once and it was a bloodbath. I might also try a store-brand twin blade. The hair on my head is definitely softer. Also there's half as much as there would be if I had a full head of hair... :)
Dr. Hess
Dr. Hess MegaDork
12/16/14 10:36 a.m.
Has anyone else tried Harrys.com? I heard an ad on WSJ This Morning and got a starter set for ten bucks. Three 5 blade cartridges, handle and some lather stuff. Refills are about 2 bucks a cartridge. Free shipping. It's different than using a Mach3, but I'm getting the hang of it. The Mach3 price of 4-5 bucks a cartridge was just getting to me, and they don't seem to keep their edge much anymore, as noted.
slefain
slefain UberDork
12/16/14 10:38 a.m.
Do you use pre-shave oil? I use this stuff:
http://www.theartofshaving.com/Pre-Shave-Oil/00670535100034,default,pd.html?start=5&cgid=shaving-products-pre-shave-oil&navid=shaving-products-pre-shave-oil
Yes it is not cheap, but it is scented and has magical effects on my wife (which I very much enjoy). I put on the shaving oil, lather up with shaving soap, then shave with a DE (loaded with cheap blades) and I get zero cuts and baby butt smooth skin to frame my manly beard.
rob_lewis
rob_lewis SuperDork
12/16/14 10:43 a.m.
slefain wrote: Do you use pre-shave oil? I use this stuff: http://www.theartofshaving.com/Pre-Shave-Oil/00670535100034,default,pd.html?start=5&cgid=shaving-products-pre-shave-oil&navid=shaving-products-pre-shave-oil Yes it is not cheap, but it is scented and has magical effects on my wife (which I very much enjoy). I put on the shaving oil, lather up with shaving soap, then shave with a DE (loaded with cheap blades) and I get zero cuts and baby butt smooth skin to frame my manly beard.
There's also a slightly cheaper version that I've been using for a while: http://www.walmart.com/ip/Shave-Secret-Shaving-Oil-0.63-fl-oz/10324376
Plus, if you need to in a pinch, olive oil works well too, if you don't mind smelling like a salad all day.....
-Rob
slowride
slowride Reader
12/16/14 10:56 a.m.
I have some Proraso preshave something or other that I use sometimes. But it's not oil... I'll keep that in mind.
Which blades do you guys use?
Woody
Woody MegaDork
12/16/14 11:09 a.m.
I like the Schick disposables, but I'm not sure what they're called. I've tried the high end Schick and Gilette blades but I like these better. I buy the 20 packs at BJs.
captdownshift
captdownshift Dork
12/16/14 11:09 a.m.
Sheik> Gilette
Also keep your razor blade cartridge down in a cup 1/4 filled (to keep the cartridge submerged) with Mineral Oil. The blades dull due to oxidation, the mineral oil will prevent this and your blades will last for at least 6 months.
(my razor of choice is the FX diamond, great sharp twin blade on a floating flex head that's small enough to get into tight spaces and a nice weight to the handle)
HiTempguy
HiTempguy UberDork
12/16/14 11:13 a.m.
Honestly, I find any disposable single use shaver works virtually as well as anything else.
Also, literal soap used to be what shaving cream is now. I think an industry has popped up around something that isnt complicated, and they earn money off the hype.
I will say out of multi-blade razors, the gillette turbo 3 did seem the best and Ive tried them all.
Woody
Woody MegaDork
12/16/14 11:15 a.m.
Don't we have a shaving thread around this time every year?
singleslammer
singleslammer UltraDork
12/16/14 11:22 a.m.
Use the razors from http://dorcousa.com/. My wife uses these and likes them. They are 90% as good as Gilette and better than Shiek (IMO). This is what the Dollar Shave Club uses.
mndsm
mndsm MegaDork
12/16/14 11:35 a.m.
Woody wrote: Don't we have a shaving thread around this time every year?
bout every 6 months. Then someone (usually me) comes in and says shaving is for women, then a debate ensues, then the non-shaving gorillas profess the last time they shaved, and I forget the record, but someone around here last shaved in like... 1974. I only know this because I've openly challenged people to a beard contest before.
DrBoost
DrBoost UltimaDork
12/16/14 11:43 a.m.
^^ Nailed it!
captdownshift
captdownshift Dork
12/16/14 11:48 a.m.
insert "I haven't shaved since before I purchased my first pair of skinny jeans, flannel button down shirt, got glasses with a thick dark colored plastic frame and drinking limited edition IPAs exclusively." comment here
Grtechguy
Grtechguy UltimaDork
12/16/14 11:51 a.m.
singleslammer wrote: Use the razors from http://dorcousa.com/. My wife uses these and likes them. They are 90% as good as Gilette and better than Shiek (IMO). This is what the Dollar Shave Club uses.
Tried both their 2 blade and 4 blade. My hair just clogs them up and they dull quickly. I keep returning to the Gillette 3 blade disposables.
singleslammer
12/16/14 11:53 a.m.
Huh, haven't run into that but the wife uses the six blade with the flex head.
wbjones
wbjones UltimaDork
12/16/14 12:08 p.m.
the last time I saw my upper lip was 1969 … I shaved for 6 mo in '86 …other than that a full beard since '69
waiting for someone to top that
foxtrapper
foxtrapper UltimaDork
12/16/14 12:12 p.m.
I'm all the way back to an old double edge safety razor myself. And, I have a beard.
Anyhow, look on Amazon for one of the variety packs to experiment with. There are blades from all over the world, and from companies I never had heard of, as well blades from companies I do know, but never heard of the particular blade.
Try them and find the ones that work well for your face and your razor. Then buy a bunch. For me, the blades of choice are Trig, Treet and Big Ben. All cost me about $12 for a pack of 100 blades. Which is a whole lot cheaper than the multi-blade things, and those three shave me far closer.
nderwater
nderwater PowerDork
12/16/14 12:37 p.m.
We also use DorCo because they offer similar styles and features to Gillette and Schick, but with lower standard prices and frequent sales/promotions via their web site. I hold out for big sales (25-35% off plus free shipping) then buy cartridges in bulk for myself and my wife.
I've tried every style they sell and I prefer the five and six blade offerings (moar power!). Dorco only offer one hinge type, so all their cartridge styles work with all their handles.
Streetwiseguy
Streetwiseguy PowerDork
12/16/14 1:01 p.m.
I've used these for quite a while. Got no significant complaints.
Thinkkker
Thinkkker UltraDork
12/16/14 1:30 p.m.
I use this
Dr. Hess
Dr. Hess MegaDork
12/16/14 1:50 p.m.
I used one of those for years, Thinkkker. Back then, I was on a ship and had nothing else to do. Wrap leg around bulkhead, shave. These days, I don't have time for it.
FSP_ZX2
FSP_ZX2 Dork
12/16/14 1:56 p.m.
Dollar Shave Club
I feel like giving this guy the business just because his commercials are so epic.
I've been using Wilkenson Sword Tech3's from Wallyworld. They are sold in 4-packs for about $4. Don't see any difference vs. the "name brand" disposables that cost much more.
mndsm
mndsm MegaDork
12/16/14 2:01 p.m.
the last time I saw my upper lip was 1969 … I shaved for 6 mo in '86 …other than that a full beard since '69 waiting for someone to top that
I thought it was you that had it...
jxOMoz1fwoePvwANTlHPCP6nrNU2kEJGsTfRVGdqueTnMpQxRJ0BMb484GUd5ZOi
