HunterJP
HunterJP Reader
5/18/12 12:00 p.m.
Long story short, I need to locate a starter wire in a 2009 Highlander Hybrid, that can be disrupted. Car must not start when this is done. I have looked at all the usual wiring sites, and have found nothing of use. I have also found nothing to use in the vehicle, at this point.
Anyone have any leads?
N Sperlo
N Sperlo UberDork
5/18/12 12:02 p.m.
Judy curious. Security system?
HunterJP
HunterJP Reader
5/18/12 12:18 p.m.
Kinda sorta? But no. LOL. Breathalyzer.
GameboyRMH UberDork
5/18/12 12:20 p.m.
Hope the car isn't manual then
Cone_Junky
Cone_Junky Dork
5/18/12 12:24 p.m.
I just pulled up the ign switch wiring diagram on ALLDATA. Unfortunately it was scanned in poorly, so you can't see any text on the diagram.
Hopefully someone else can post a good image of the ignition diagram.
HunterJP
HunterJP Reader
5/18/12 12:52 p.m.
Forgot to add, this one is push button. So the pink wire in the 7th pin, won't work.
HunterJP
HunterJP Reader
5/18/12 1:29 p.m.
Cone Junky, thanks for looking! I appreciate it a ton.
In response to Gameboy, roll start it all you want, unit will know the motor was started without a test, and violate you.
chaparral
chaparral Reader
5/18/12 5:21 p.m.
Don't use the starter wire. That has huge current flowing through it and can be bypassed readily with a jumper cable.
Use the crankshaft position sensor wire to the ECU. Put the disconnect relay right next to the sensor - if possible, hardwire it in - and the car will not start if it's disconnected. The starter will spin but the engine will never fire.
Fit_Is_Slo
Fit_Is_Slo HalfDork
5/18/12 10:46 p.m.
It doesn't have a starter per se, it has a motor generator that will spin the engine on command.
tfkSdBdAj9lGjyixA7vHbEQKiTGyfckOrROfjM9707JurToRasm5yK5upSeSEiVh
