lnlogauge
lnlogauge HalfDork
2/15/22 6:20 p.m.
I bought a mini freezer for cheap to get by until I find a deal on a bigger unit. The issue I have is it's a 250v two prong europlug. My garage has 240v so I was going to wire it in there, but I don't really want to cut the cord if I'm going to resell it. Any American solutions on how to use this?
Curtis73 (Forum Supporter)
2/15/22 6:32 p.m.
Pull the strain relief panel off the back where the cord disapears into the unit.  You'll almost certainly find that the cord goes into a J-box where it is wired to the other wires inside.  It might be on screw binding posts or just wire nuts/crimps, but you can remove  the pigtail and go buy/make a proper pigtail for your outlet.
There is a whole row of this in the appliance department.  Since outlet protocols changed a dozen times over the years, most appliances are sold without a cord.  You buy the pigtail that is appropriate for your outlet.
2/15/22 6:33 p.m.
Like this:
2/15/22 6:35 p.m.
I'll also add.... unless you're planning on reselling it in Europe, I wouldn't worry about cutting the cord to install the right plug.
lnlogauge
lnlogauge HalfDork
2/15/22 6:39 p.m.
Thank you!!!! Already have a spare cord like that, but didn't think about changing it at the unit. Really appreciate the help!
Slippery
Slippery UberDork
2/15/22 6:52 p.m.
Its 50/60 hz, right?
APEowner
APEowner SuperDork
2/15/22 6:59 p.m.
Make sure the unit itself is rated to run at 60hz.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
2/15/22 9:59 p.m.
Are you sure the freezer isn't a dual voltage unit already?  Is it labeled 250V-50Hz or something like 100-240V 50-60 Hz? I've seen other appliances that work on either, but can't say I've ever looked at a freezer specifically.
birdmayne
birdmayne Reader
2/15/22 11:19 p.m.
Move to Europe?
lnlogauge
lnlogauge HalfDork
2/16/22 6:48 p.m.
In reply to APEowner :
Also things I didn't consider. Probably should have looked into this a little more before purchasing.  Tag says 50hz. But, Google says that most motors run fine on 60hz. As long as it doesn't catch on fire I don't really care. Only paid 40$
q8W6q5tmYStQQdT4LVRWdSNkoy5lZC6ZZ9DEErycPI2IBX44cfF8mX3Hv59TMvJ5
