Conquest351 wrote:![]()
combine that with mech fi.
ransom wrote: In reply to yamaha: Fair enough. Just wanted something SC related to hotlink while replying to the lag joke... If I do SC, I don't think it'll be a DASC setup... Wonder if it's possible to build a clutched arrangement hybrid turbo/centrifugal SC... Let the crank get it moving and then let exhaust take over powering it after the initial start. Probably get all the exhaust restriction of a turbo with all the inefficiency of an SC![]()
Or, howabout a centrifugal supercharger paired to a CVT to generate optimal boost at all engine speed with minimal drag on the rotating assembly?
4cylndrfury wrote:ransom wrote: In reply to yamaha: Fair enough. Just wanted something SC related to hotlink while replying to the lag joke... If I do SC, I don't think it'll be a DASC setup... Wonder if it's possible to build a clutched arrangement hybrid turbo/centrifugal SC... Let the crank get it moving and then let exhaust take over powering it after the initial start. Probably get all the exhaust restriction of a turbo with all the inefficiency of an SCOr, howabout a centrifugal supercharger paired to a CVT to generate optimal boost at all engine speed with minimal drag on the rotating assembly? YUP, ITS A BRILLIANT IDEA![]()
McCullough (Paxton) had a variable speed supercharger in the '50's:
Streetwiseguy wrote:Gasoline wrote:Is that a ruined Chevelle, Torino, or what?![]()
Window kinda looks Torino-ish. Still bad, as in useless, undriveable sculpture.
Aussie Falcon, I think.
The supercharged MR2 has a clutch on it's pulley. It even has a little green light on the dash that tells you when it's "Super Charger"!
The Mercedes clutched M62 is a popular choice among MX6/Probe owners.
This is not one of those i don't think.
Looks like there's a cover on the prop? Providing turn signals and hopefully some degree of protection?
914Driver wrote: A coupla high speed rocks at the prop and I'd be looking for a bus.Gasoline wrote:![]()
jakeb proves there's room for a turbo M42 in a 2002. I'm still scared.
ransom wrote: Looks like there's a cover on the prop? Providing turn signals and hopefully some degree of protection?914Driver wrote: A coupla high speed rocks at the prop and I'd be looking for a bus.jakeb proves there's room for a turbo M42 in a 2002. I'm still scared.Gasoline wrote:![]()
WOW thats a tiny turbo...its like a turbo for a baby!
Yes. I assumed the prop was just for show since it was not a flyable aircraft due to the MC ass screwing up the CG. However, I started to think it could be fairly easy to remove and stow for flight.
