GI_Drewsifer
GI_Drewsifer Reader
6/4/10 6:20 p.m.
So, been rolling in the Golf lately. It's in need of some love. Needs new rear brake pads and the accessory belt is dire need of changing (thanks Father-in-law). However more pressing, the trip computer and in dash clock keep reseting. Maybe this is as simple as the battery cables being lose? Any other thoughts?
Drew
grimmelshanks
grimmelshanks Reader
6/4/10 7:00 p.m.
sounds likely
John Brown
John Brown SuperDork
6/4/10 7:39 p.m.
OR you have got a power supply relay or fuse box going bad.
EricM
EricM Dork
6/4/10 9:18 p.m.
bad ground? that's all i got.
EastCoastMojo
EastCoastMojo SuperDork
6/4/10 10:16 p.m.
Flux capacitor is loose.
grimmelshanks
6/4/10 10:41 p.m.
ya you blew the o ring out of your turd cutter leading to a bad fartknocker valve
GI_Drewsifer
GI_Drewsifer Reader
6/5/10 7:19 a.m.
Oh man, how much to fartknocker valves go for? I don't think I know enough to do one of those myself.
egnorant
egnorant Dork
6/5/10 9:33 a.m.
Had this happen with a dead cell in the battery. Still had juice to run and drive, but starting it would drag the voltage below some level and erase stuff.
Hocrest
Hocrest Reader
6/5/10 7:34 p.m.
Check your fuses, those things get power from 2 fused sources. A constant fused 12v to feed the memory and a second fused power supply tied to the ign switch or relay that actually powers the display.
mad_machine
mad_machine SuperDork
6/6/10 10:08 a.m.
when does the trip odo and radio reset? If it happens on restart, I agree with egnorant.. sounds like a battery going out. If it happens when going down the road, it is likely a loose wire or ground.
Not that VWs have bad electrics or anything...
thatsnowinnebago
thatsnowinnebago Dork
6/6/10 11:57 a.m.
AFAIK, that's par for the course for a VW....
UZb8smmWcKyMMHsKTIHtU3MIAv4Fb9a1edBucRudCOXplaRNYyM9J4JS4WbUTp4D
