Not sure if this applies to Verizon devices, but it won't hurt to check..
Find out if your smartphone is unlocked BEFORE making a port request. I had to pay a fee after porting a locked TMO smartphone. The lock berkeleyed up the port procedure, meantime the old account was closed.. so I had to re activate ($) on old carrier, request unlock (took a week) then finally unlock before I could use the new sim. Something about a ($) bag of dicks comes to mind...
PHeller
PowerDork
3/27/14 12:04 p.m.
JohnRW,
Is there any advantage or saving for using PagePlus standard plans versus monthly plans?
I'm finding that I don't use anywhere near 1200 minutes or 3000 texts, but I'm managing my data usage constantly and I felt like I burned through 500mb pretty quick.
Are you burning through data quickly?
Let's check.
Text BAL (short for balance) to PAGE
The answer you get back on data will be how much data you still have.
PHeller
PowerDork
3/27/14 12:44 p.m.
I have a 183mb of data left, but thats with constantly turning on/off mobile data.
In reply to PHeller:
Since this is a new handset to you, have you downloaded a lot of Aps? If possible, do this over wifi.
Do you have home wifi?
If yes, also go into The Google Ap store (Play Store). Once there, get into the settings of the Ap store. Be sure it is set that Aps will only update over wifi.
This should help reduce your data-thirst.
Reduce video use and do not move photos till you are on wifi (like if you are uploading to Photobucket.)
The $29.99 plan you are on charges 5 cents per mb for overage data. That means 500mb more would cost you another $25. If you are going to be using this much, then you could consistently spend the extra $25 to get the $55 program which gives you 2.5gb.
Personally, I have never turned on/off my cell data.
I check GRM, my local newspaper and a number of other websites alot. I use the wifi function at home. I am not on the book of faces. I only use Pandora, etc over wifi.
I have used less than 200mb since the 5th of last month (3 weeks usage.)
donalson wrote:
if I recall correctly pageplus doesn't officially support the iphone... I got my phone from a friend who upgraded... I did some digging and found the link of who I had activate it http://www.remotesquad.com/free-page-plus-activation/
So do I have to unlock my phone before I port it?
honestly I don't know... I got mine used with a good ESN from a friend who upgraded... the easiest way to go about this would likely be goto one of your local pageplus dealers :-/
