foxtrapper
foxtrapper PowerDork
11/12/12 8:39 p.m.
If you're working for it, your chain isn't sharp.
Really.
Read through this thread, follow the links and load the videos.
http://www.arboristsite.com/chainsaw/198416.htm
It's also why I said to sharpen your chain every time you add gas. It's not excessive. If you're exerting yourself, your chainsaw isn't cutting.
curtis73
curtis73 SuperDork
11/12/12 10:01 p.m.
Here is something that is often overlooked. If the sharpness OR angle of the teeth is different on each side, it will cut a curve. I would look to your sharpener. You have good chains but maybe the cutters aren't even left/right.
I used to sharpen my own but I couldn't get the right edge. If I didn't get both sides perfect, it cut a curve. I still do my own touch-ups while cutting but I let my neighbor sharpen. He has a killer sharpener setup with digital angle display.
TRoglodyte
TRoglodyte Dork
11/12/12 10:50 p.m.
Practice, same with an axe. Takes time to get it right
bearmtnmartin
bearmtnmartin Reader
11/12/12 10:57 p.m.
Really, chainsaws are for wimps anyway.
http://www.youtube.com/watch?v=Y4lky9VW6tE
bearmtnmartin
11/12/12 11:00 p.m.
But if you are using a chainsaw, it should cut something like this...
http://www.youtube.com/watch?v=kHVufn2nKD0
fasted58
fasted58 UberDork
11/12/12 11:03 p.m.
maybe run premium fuel
http://www.youtube.com/watch?v=FvAI7-Qa2Io
bearmtnmartin
11/13/12 12:41 a.m.
I guess you have to know that if they make it someone will attach a smallblock chev to it eventually.
Vkh079vTuWPr3tMIjUy6VAJdkr4Y3U4XeYYNp1qihPGlvLc6siNt4GRBAoI7qnjF
