rob_lewis
rob_lewis Dork
2/1/10 10:18 a.m.
Searching just shows me how Aimsoil is better than any other type of oil.
Got a portable compressor for Christmas and I have to fill it with compressor oil (15w/30). Is there anything special about compressor oil over conventional motor oil? I'm sure motor oil has detergents that the compressor doesn't need.
Any reason why I can't use just regular oil?
-Rob
Jake
Jake HalfDork
2/1/10 10:21 a.m.
In reply to rob_lewis:
Mine just has the bottle of compressor oil that was on the shelf at Sears when I went to pick it up. Probably about due for a change.
Trans_Maro
Trans_Maro HalfDork
2/1/10 10:26 a.m.
Conventional oils will foam.
Buy the stuff labelled "Air Compressor Oil" or any 30-wt non-detergent.
Shawn
porksboy
porksboy Dork
2/1/10 5:13 p.m.
Are all comps. 30wt? Are any 90wt?
Jensenman
Jensenman SuperDork
2/1/10 6:55 p.m.
My compressor (Home Depot Husky 60 gal) came with a big tag attached with a warning to use only Mobil 1 0w30 oil. So that's what's in mine.
Trans_Maro
Trans_Maro HalfDork
2/2/10 12:00 a.m.
Repaired lots and lots of compressors at my shop. All we ever used was 30wt ND dino-juice.
If you run 90, I'll bet the added drag will trip your circuit breaker.
Shawn
motomoron
motomoron Reader
2/5/10 9:27 p.m.
I needed to change the oil in the compressors at home (Speedaire-5hp-60gal-2stg-quad) and at work (Also Speedaire-5hp-80gal-2stg-2cyl).
Since I'm happy to drop $100 on a fluid change for the M3 and love my big green compressor so dearly I threw down when I was ordering from McMaster-Carr and got a gallon of Mobil Rarus 427 compressor oil. It stays very clean, and it's cool having gallons of industrial lubricants around the shop. I also use Mobil Vactra #2 way oil on the machines, and #4 on vises.
Dr. Hess
Dr. Hess SuperDork
2/5/10 9:40 p.m.
If you like the Mobil industrial lubes, check out Mobil SHC630. Dunno about compressor applications, but I use it in any gear application that doesn't have syncros or clutches (too slippery).
Jack
Jack SuperDork
2/9/10 1:45 p.m.
It's a piston with rings, just like a car, so I broken mine on no-detergent motor oil with all the valves wide open, so it was not working hard, then switched to Mobil 1.
Jack
0hZ8H2JkBHAmrgi5j910vUNjrpFOc79dtAqk61HIIctfmRMQqpNcviaeOIAJYRtb
