RevRico
PowerDork
5/24/20 3:07 p.m.
Turns out the yard isn't as level as I thought.
I've been crunching numbers and it seems about equal cost to pour a 6" thick patio or build a wooden deck that can support the pool.
I actually suspect concrete would be a bit cheaper, but definitely more labor intensive. Wood would all need to be marine grade and at least doubled up from a regular deck because of the weight and motion. 2x10s at 12"centers, 4x4s buried at least 3 feet deep and cemented in, x bracing every or every other span, the wood would add up quick.
I can rent equipment to move dirt, and a transom to make sure my gravel layer is level before pouring, but sinking and cementing 4x4s would be much easier prep wise.
Which way should I lean?
Neither one is happening this year, the money just isn't there, I'm just trying to figure out for the future.
Current pool is a 15ft round 33 inch deep affair that holds 2500 gallons, at 8lbs/gallon, that's almost 10 tons.
Possible future pool is 12 ft diameter, 4 feet tall, I think 3000 gallons capacity.
That's a E36 M3 load of weight.
Would I be better off in the long run just digging a big berkeleying hole and planting an in ground pool?
I like the idea of tearing down every winter instead of winterizing, but the way incidental costs add up it could wind up cheaper.
02Pilot
UltraDork
5/24/20 3:14 p.m.
Level the ground, cover in sand, put the pool on the ground. Build a wooden deck up around it, partially or totally, fence whatever you don't border with deck. Easier to just get an above-ground permanent pool - winterizing is easy.
This is just my opinion, and I certainly don't wish to offend you, but putting a pool on a wooden deck is a fools errand.
RevRico
PowerDork
5/25/20 8:06 a.m.
In reply to Streetwiseguy :
Yea I kinda thought so. But figured I'd ask anyway.
Sand. How did I forget about cheap, plentiful sand?
We drained and moved the pool yesterday, it's much much better than it was. I need to find a good permanent marking solution for when it comes down so I only have to fill it up once next time. This paying for water E36 M3 isn't nearly as nice as my unlimited well was.
02Pilot
UltraDork
5/25/20 8:34 a.m.
And that's why I suggested a permanent installation. Winterizing is three chemicals (on a chlorine system - I don't know if it's different for salt or other systems), draining down a few inches, and cover. Opening is even easier, and much cheaper if you only need to bring it up 2-3 inches rather than fill the whole bloody thing.
