OHSCrifle
OHSCrifle UberDork
11/11/23 9:51 a.m.
My 2012 highlander has a constant light but no air leaks. Failed sensor I suspect. Not the kind that monitors each tire - just a general light. I have an OBD reader but just basic type.
Are these sensors user replaceable or is it best to pay the man?
93gsxturbo
93gsxturbo UltraDork
11/11/23 10:15 a.m.
Testing:
  • Get a copy of Techstream and VXDiag cable - the cheaper cables can not write to the TPMS module in most Toyotas.
  • Read the TPMS codes, determine which sensor needs replacement by letting air out of the tires 1 at a time and seeing which one(s) don't work/report the pressure change in techstream.  Its usually pretty fast, within a minute or less.  Do one at a time.
Once you determine the bad sensor(s)
  • Remove the wheel from the vehicle and break one bead with a floor jack (youtube videos for this)
  • Press the bead down near the TPMS and remove it from the rim
  • TAKE A PICTURE OF THE CODE OF THE NEW TPMS
  • Install the new TPMS, air up the tire, reinstall it.
  • Air up all the tires to the pressure listed on the B pillar sticker.
  • Write the new code in place of the code of the defective sensor using Techstream.
  • Light should go off, take a short drive to confirm
Thats the easiest way I have found to do it at home without many specialized tools.  The VXDiag cable and techstream are super helpful and around $100.
Datsun240ZGuy
Datsun240ZGuy MegaDork
11/11/23 10:21 a.m.
Pay the man.
Every car that hits the 10-12 year mark with original sensors gives me trouble.  If one is bad the rest will follow. You do know there is a battery inside the sensor.
Discount Tire was $60/wheel and I replaced all four in the daughters car since she is 300 miles away at college.  Now it all works perfectly.
Shop around - Wally World was $35 but hadn't had replacements for 3 months.  One guy told me $100....a tire....
OHSCrifle
OHSCrifle UberDork
11/11/23 10:29 a.m.
Always more to learn here. Not disappointed. Thanks
warpedredneck
warpedredneck Reader
11/14/23 10:36 a.m.
some Toyota's have a tpms in the spare, check the pressure in it, if it was low do a 5 tire relearn,
and then recheck it by doing a couple drive cycles
MKvuACCA2LgQBBQnbfREZNuikkZBj5iGC4fYYXCRyvd3SaV9ZeMCDRm5FaX7KcaL
