If I do this I don't want a huge project. A little project, maybe, but not a big one. I'll consider it, though. I have swapped engines over a day and change, but changing types (6.5 to 6.2) might be weird, especially since I don't know a lot about diesels.
Good point... another suggestion is to find a GMT4 with a good 6.5TD that has a bad PMD. Swap it over to the 6.2 mechanicals - or repair the PMD and enjoy another 200k. People think the 6.5s suck, but they are actually wonderful designs... a bit dated, but wonderful.
RE transmissions, I need an overdrive, so it's MY6, NV4500 or the internet-hated NV3500. I did do the math, the overdrive makes even the 4.10 lower than the lowest factory installed gears. Time to hit the yards, I guess.
The NV3500 wasn't terrible, its just nothing to write home about. My commentary (having run transmission shops for a long time...)
You can't assume that torque = torque... a gas engine making 500 lb ft seems like the same as a diesel engine making 500 lb ft, right? Its not necessarily the case. Two things come into play. Gas engines make pulses of power that fade. Their harmonics are dictated by the lower compression they start with and a fast, but fading flame front. All of the intake charge is already there when ignition occurs, so its just a matter of the combustion "throwing" the piston and letting inertia work its magic. With a diesel, the initial compression is much higher, the light-off tends to be a bit more violent, and then fuel is injected through as much as 36 degrees of crank travel.
(I have to interject... my recent engine theories in other threads have come under scrutiny, so what I just said above is highly colloquial and not quantitative.)
What it ends up doing is creating a bit more violent harmonics than a gas engine... so a diesel with 500 lb ft will typically destroy a transmission much faster than a gas engine with 500 lb-ft.
If you had a big block gas engine, I would say that the 3500 or 3550 would be fine, but behind a diesel they won't last - doesn't matter how wimpy it is.
The other thing I'll throw out there... RPM is slightly less of a concern with diesel. In a very simplified example, in the gas engine, your right foot determines how much fuel is injected per cycle. If you increase the number of cycles (raise the RPM) you'll typically use more fuel. Given the diesel's rate of injection being more closely related to your right foot, its MPG is more closely related to your foot position than it is RPM. In a gas engine, I like to see highway RPMs about 500-1000 RPMs lower than peak torque for max MPG, but in a diesel, shoot for highway RPMs at the point where it requires the least "foot" to maintain speed. That's a bit difficult to calculate, but it often occurs at or above peak torque in a diesel.
She still likes the later ones better.
Sounds like you have two choices - hold out for a later model truck, or ditch her and get a later model girl ![](/media/img/icons/smilies/evil-18.png)
