CarKid1989
CarKid1989 SuperDork
7/14/20 5:25 p.m.
I was wondering if anyone here has made their own leveling legs or has any insight on making them.
I have a Harbor Freight 44 inch toolbox that I am making stationary (removing the casters) and i have seen people making leveling legs out of bolts/ threaded rod and hockey pucks. Others buy inserts that fit inside square tube and those come with adjustable feet.
The toolbox will be full of tools but I wont be packing it chock full to the gills where its overweight so that will help but I still have a good amount of weight in it. HF listed max working load at 2600 lbs so each foot has to hold 650lbs plus some extra margin.
I was thinking I could save some money by making a set (well, 2 sets of 4 legs)
I have seen an example that used 5/8 bolts and washers and nuts sandwiching the $1 hockey puck and that seems to work. What I cant find is weight rating of a $1 hockey puck leveling legs.  Is 5/8 big enough or go bigger?
Then I see some have made cups to hold the hockey puck so it does not squish too much laterally. That seems excesive. But, would have a washer the diameter of the puck help spread the weight?
I have some many questions but I cannot join all the various forums that I see these ideas on to ask so I am here asking you for help and insight.
Am I over complicating this? Suck it up and buy leg bases for $10/per.
I appreciate any ideas
mikeatrpi
mikeatrpi HalfDork
7/14/20 6:43 p.m.
I used pieces of pvc 1x6 boards to make two skis, and countersunk the bolts using a forstner bit.  I know this isn't leveling feet but if your floor is close to level there are alternatives to feet when you remove the wheels
Patientzero
Patientzero HalfDork
7/14/20 6:50 p.m.
I think 5/8" would be plenty, it's in compression. I would keep it as short as possible to limit side loading of your mounts and making your toolbox wobbly.  A fender washer or a few on top would probably be a solid idea.
CarKid1989
7/15/20 4:14 a.m.
i like the skid idea but the garage floor where the box is going is too uneven for that kind of setup.
D2W
D2W Dork
7/15/20 10:21 a.m.
https://www.mscdirect.com/browse/tn/?searchAheadTerm=leveling&searchAhead=true&searchterm=Stud-Mount+Leveling+Pads+%26+Mounts&hdrsrh=true&typahddsp=Stud-Mount+Leveling+Pads+%26+Mounts&tg=Matching+Categories
Unless you really just want to make your own. 5/8" bolts are more than enough, and the hockey puck will never deform under the weight of a tool box.
sH1SNE3Ky5cQp2uqN7UkBrKZBeIojhdCVnfHh87XyluHaXNgeojbrrVKLI8HuUgq
