Slyp_Dawg
Slyp_Dawg HalfDork
8/14/15 12:18 p.m.
I've amassed a small collection of .50cal ammo cans (tactical tupperware ) and want to turn one of them into a basic roadside emergency/survival kit to bolt down either in my Miata's trunk or to the roll bar (no soft top so actually decent amount of room on the parcel shelf around the roll bar) and I need some ideas of what to put in it. Obviously jumper cables and some sort of roadside signalling thing (triangles, blinky puck, flares, etc...) and maybe some basic tools, but what else? Only real stipulation is that it has to fit into a .50cal ammo can (11x5.5x7" steel box with a rubber seal for anyone not familiar with them) without having to hack up the can. Thoughts?
8/14/15 12:44 p.m.
Other than tools, a knife, crank-powered LED flashlight, and the other usual stuff, I have a folding sheetmetal wheel chock that came with a jack I bought.
I also have a mylar space blanket, and an awesome Tyvek hoodie that is extremely light and folds up to be tiny, but is also pretty impervious to water.
ValuePack
ValuePack SuperDork
8/14/15 1:45 p.m.
I'd add a tow strap too, if you have room.
And as one who once caught a backpack full of sockets in the back of the head when crashing into the woods, tie that bish down good if you go roll bar mounted.
92dxman
92dxman Dork
8/14/15 3:30 p.m.
Multitool and some pliers.
bgkast
bgkast UberDork
8/14/15 3:36 p.m.
.50 Cal ammo?
Toyman01
Toyman01 MegaDork
8/14/15 4:00 p.m.
I carry two cans and bag if I'm going off the beaten path. Probably more than you want, but a ammo can will hold a bunch if you pack it right.
Kenny_McCormic
Kenny_McCormic UltimaDork
8/14/15 5:42 p.m.
Tire plug kit (plugs, reamer, plug tool, rubber cement), air pump, tire gauge, two of those HF led worklights loaded with fresh alkaline batteries.
oldtin
oldtin UberDork
8/14/15 5:55 p.m.
Cell phone, aaa card, credit card.
What's likely to break on a Miata you can fix on a roadside? Will you have spare parts too?
codrus
codrus Dork
8/14/15 7:17 p.m.
Depends on how far out into the wilderness you're going. If it's far enough, an EPIRB/PLB wouldn't be a bad idea. :)
epirb
Toyman01
Toyman01 MegaDork
8/14/15 7:27 p.m.
In reply to codrus:
Or a Spot.
93gsxturbo
93gsxturbo Dork
8/14/15 8:58 p.m.
Dont forget a small generator.
stroker
stroker SuperDork
8/14/15 9:34 p.m.
See if you can find Peter Egan's article on his "tool kit" in a 35mm film canister.
Knurled
Knurled UltimaDork
8/15/15 10:16 a.m.
Kenny_McCormic wrote: Tire plug kit (plugs, reamer, plug tool, rubber cement), air pump, tire gauge, two of those HF led worklights loaded with fresh alkaline batteries.
MULTIPLE tire plug kits.
It's not the slow-leak screw you have to worry about. It's the giant hole that needs seven plugs every fifteen minutes to get the tire to hold air long enough to get you to civilization
Knurled
Knurled UltimaDork
8/15/15 10:18 a.m.
oldtin wrote: Cell phone, aaa card, credit card. What's likely to break on a Miata you can fix on a roadside? Will you have spare parts too?
The guy who drove a Miata from Florida to Iowa to compete in the Rallycross Championship rebuilt his clutch hydraulics on the side of the road.
oldtin
oldtin UberDork
8/15/15 12:52 p.m.
Schlepping across country for a competition is one thing - I'd probably have a trailer full of spares & tools. Emergency kit for everyday - jumpers, relays, fuses along with cell, aaa, credit card.
madmallard
madmallard Dork
8/15/15 4:01 p.m.
hmm...in mine I have:
+fluffy winter gloves +5$ socket ratchet set +road flare +tripod led flashlight +scraper +20' jumpers +tire iron +notepad and sharpees +hammer +hex multitool +screwdriver-bit handle set +OSHA green safety t-shirt +pancho and garbage bag +triangle +bottle of water +USB micro cable +PS fluid and a quart of oil +bottle of aspirin +AA batteries +shop towel roll +lighter & matches +tire plug kit +zip ties, electrical and duct tape
and the board's syntax guide on making a list seems to not work.
novaderrik
novaderrik UltimaDork
8/15/15 4:49 p.m.
i have 2 tow straps, 3 big and a couple small ratchest straps, good jumper cables, and a few different hitch receivers with different balls on them under the back seat of my truck. i've got a 20 year old Craftsman 12 volt air compressor under the front seat... now that i think about it, i've also got a small tool bag with a $3 Wal Mart sae wrench set (which is almost totally useless on a 97 Chevy truck that is all metric except for the stuff that bolts to the engine block or heads), a couple of worn out cheap screw drivers, some fuses that don't fit in any slots in the vehicle, and a tire plug kit...
dean1484
dean1484 MegaDork
8/15/15 5:36 p.m.
Advanced first aid kit. Hopfully not for you but having happened on some situation's over the years I am glad to have had one.
Kenny_McCormic
8/16/15 4:37 a.m.
MULTIPLE tire plug kits. It's not the slow-leak screw you have to worry about. It's the giant hole that needs seven plugs every fifteen minutes to get the tire to hold air long enough to get you to civilization
This is why I tend to carry more than one spare tire when conditions call for it (winter, long trips, etc.).
Will
Will SuperDork
8/16/15 9:55 a.m.
A head lamp can be much more useful than a flashlight if you need both hands.
Also, I'd consider keeping emergency tools and emergency survival stuff separate. To me they're two different things, and either can easily fill up a .50 cal can on its own.
In the tool can: tools to repair the car.
In the survival kit: water, food, fire, first aid, emergency blanket, rain poncho, etc.
(I'd also not store any food/water in a used ammo can, but that's just me.)
fritzsch
fritzsch Dork
8/16/15 10:22 a.m.
An extra pair of socks
T.J.
T.J. UltimaDork
8/16/15 10:27 a.m.
I carry the factory jack and lugnut wrench in my Miata. I save my travelling toolboxes for the Mini and the boat. I also don't routinely drive the Miata farther than 45 miles from home.
slantvaliant
slantvaliant SuperDork
8/16/15 11:24 a.m.
Don't forget your towel.
raaMW5epW4Ci3YtzC69SO2ys9xlfzhCLpmlVkLymXpRxJ9bJ0EQo6A1NWUNpFziZ
