Periodically my Acer just goes black. A light tap brings it back to life.
Is that its way of saying that it no longer wants to play?
Yep, specifically it sounds like a loose solder joint. In the days of CRT monitors these were common where wires met the magnets that diverted the beam one way or another, so your image would turn into a line and smacking the monitor would fix it temporarily. Yours is probably at connection to the backlight system or a signal wire.
Thanks for the confirmation. Yeah, it's LCD: http://www.amazon.com/Acer-X233H-bid-23-Inch-Monitor/dp/B001OD76SG
David S. Wallens wrote: Thanks. Shopping right now....
I do a lot of graphics-rich stuff and I am a big fan of Samsung monitors. Great detail and color and very little eyestrain.
I ordered an LED Acer. I figure this one gave us years of service. The new one should be here tomorrow. I know, so exciting.
And whenever discussing monitors, it's hard not to think about this: https://en.wikipedia.org/wiki/USS_Monitor
So, like 10 minutes after I hit "purchase," the doorbell rang and it was the mailman with a package from Amazon. Sadly, though, it was not my monitor.
Just to clarify here, the monitor you just ordered is an LED backlit LCD monitor. Your old monitor was likely a CCFL (cold cathode fluorescent) backlit LCD.
David S. Wallens wrote: And whenever discussing monitors, it's hard not to think about this: https://en.wikipedia.org/wiki/USS_Monitor
Ah, a Civil War History buff!
Toyota monitors do not go bad. Had that original monitor been made by Toyota, it would still be running. Alas, GM and Dodge monitors are not as reliable, and if you ever have to deal with an English made monitor, you will run screaming for the Toyota dealer.
English made monitors are fine, you just have to keep a drip pan under them to catch the leaking oil.
