I'm getting ready to install my bendpak P6 lift that's been sitting in the garage for almost a year now. Can I drill in the concrete without a hammer-drill? do I need a special drill-bit or the multi-purpose B&D drills will work?
I'd hate to have to buy a hammer drill for 6 holes.
My understanding is that an impact drill is the way to go and it does take special bits for concrete work.
SVreX
SuperDork
3/21/09 1:02 p.m.
Rent a hammer drill at your local tool rental store. They can help you with the right bit, too. You'll need carbide or diamond (your twist drills won't even come close- they will melt during the first hole).
The holes you will be drilling are large. You need a good tool.
Actually, I was thinking 2 post lift- your scissor style will have significantly less strain on the bolts (and they are probably smaller), but you should still make DARNED SURE you are installing COMPLETELY in accordance with the manufacturer's specs. Read them carefully. They will probably discuss concrete thickness, type of bolt, anchoring method, grade of bolt, etc.
It's a car lift. It can kill you.
Plus 1 on renting the hammer drill. I just did 4 5/8" holes with a carbide masonry bit and a regular 1/2" drill, it was a PITA.
Like SvreX says, don't mess around because your life depends on this being mounted properly! The last thing you need is one side coming adrift with a ~2500 pund car on it.
A decent hammer drill isn't all that expensive, and sometimes it is nice to have a nice corded drill around the house. A good drill bit is worth the extra money spent on it.
This is the sort of thing Harbor Freight is perfect for - a tool you will use once in a blue moon.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=45338
They have a cheaper one than that, but I'd pay the extra $10 to get the orange one. Their orange tools almost always last for a while if you only use them once or twice a year.
This the one I have, and have been very happy with it. Used it to drill dozens of holes in a foundation wall.
craftsman drill
cwh
Dork
3/21/09 4:47 p.m.
30 years of experience drilling in concrete. Hammer drill, corded, minimum 1/2". I always used a pro grade drill, but was doing it all the time. Carbide tip masonry drill bit. MAKE SURE YOU ARE USING THE CORRECT FASTENERS!!!!! There are a number of anchors that will work in concrete, but ONLY use the one recomended by the manufacturer. They will probably be one of the expansion types, but again, only use the one they require. Also, try real hard not to drill off vertical. You want a straight hole to the depth they are after. This is no time to get sloppy or cheap out.
what this guy above said. if he has 30 years experience and is talking......listen
Like cwh sez regarding the fasteners. Home Depot/Lowes sell masonary drill bits. Get the right size for whatever fastener you are using. I put one shop's base plates down into concrete with Redhats with a cordless Makita drill with the right masonary bit. I would get one hole per charge. It took a while. The next shop, I bought a corded 1/2" Makita hammer drill and used the same bit. Went in like butter. So, could you drill 6 holes with what you have if you bought a masonary bit? Yeah, probably. But it will go a lot faster if you get a hammer drill. I bet that HF one isn't too much and will do 6 holes for you.
Thanks guys, I guess I have to go either rent or buy a 1/2" drill bit and a couple of masonry drill bits. All the hardware came with the lift so I'll be using exactly what the manufacturer sent me. I spent most of today unpacking and setting it up. It's not ready for use yet but it's working as expected. Just needs to be fastened to the concrete properly before I actually use it.
While we're on the topic of concrete how do I cut a channel into the concrete to route the hydraulic lines. What do I need to cut concrete that way. Here's an example:
http://pubpages.unh.edu/~jjy9/liftnocar.jpg
I also need to contact bendpak about their Step 7 in instructions which talks about air lines, there were none included nor do I see anywhere they'd hook up. It's all hydraulic based so not sure what the air lines are supposed to do. Maybe the lift comes in two configurations hydraulic or air.
I went to bendpak's site and I was unable to locate any price info. Would you mind sharing the cost of that lift? That's pretty badass.
Check out this link from another owner:
For me the cost was $1800+tax but usually they go for about $2300. I wish they were slightly less expensive than the 2 post lifts because if I had the ideal garage I would've wanted the 2-poster. However, there are some advantages to this type of a lift with open access in the middle, it works like a 2 post lift but since you can park over it you don't lose any precious space in your average 2 car garage. Not to mention the ceiling issue with the 2 posters. Anyway, I thought long and hard about it and finally after mulling it over for 2 years I pulled the trigger when I got a bonus at work.
If you want nice clean straight channels, I'd use a gas powered demolition saw with a diamond tipped blade. Again, not cheap. Rent it, and in an hour or two, golden. Use your BFH to knock the concrete between the cuts loose.
ww
Dork
3/22/09 12:57 a.m.
RussellH wrote: For me the cost was $1800+tax but usually they go for about $2300. I wish they were slightly less expensive than the 2 post lifts because if I had the ideal garage I would've wanted the 2-poster.
This always amazed me too. You'd think the 2-post lift would be more expensive. It must have something to do with supply and demand. The demand for the P6 is considerably less than the demand for the 2-post so they manufacture a LOT more 2 post lifts than P6's lowering the cost of each unit.
I may put a P6 on the side of the house to work on the Lemons car...
Woody
Dork
3/22/09 7:28 a.m.
Let's see, I have a hammer drill, you have a lift in your garage....where do you live?
cwh
Dork
3/22/09 8:13 a.m.
Cheap way to cut channels in concrete is to get a masonry blade for a regular circular saw. Messy and slower than the big boy, but will do the job. Run paralell cuts as far apart as needed, then the BFH and a chisel to knock out the middle. Your saw will probably be shot when you finish. I always would use my crappiest saw, then did not worry about it. Eye protection is vital, and the concrete dust will get everywhere. Probably a good idea to get a big fan to blow it outside.
I am jealous. Very very jealous.
Woody
Dork
3/22/09 8:39 a.m.
Cut a minimum of three grooves to minimize the possibility that the broken chunks will get wedged in there when you try to remove them.
Been there.
cwh
Dork
3/22/09 9:53 a.m.
I bet if we all got together that sucker would be mounted and lifting in one hour and a 12 pack!
I thought that was just a scissor style lift....I was wondering why it had to be hard mounted. Then I looked at the picture link. That is a pretty cool setup.
BAMF
New Reader
3/22/09 12:25 p.m.
You have a lift, but not a hammer drill (or access to one)? You'll need a masonry bit that's made for concrete, and made of carbide. Once you've got all that it's simple stuff. Renting a hammer drill for a few hours isn't too expensive.
