JoeyM
JoeyM SuperDork
4/15/12 4:33 p.m.
the datsun replica is shorter than the 810 wagon donor...so much so that the E-brake cable is too long. any ideas how to fix it on a GRM budget?
Woody
Woody UltimaDork
4/15/12 4:44 p.m.
Not sure about the budget part, but look to the street rod world for some ideas.
ditchdigger
ditchdigger Dork
4/15/12 4:52 p.m.
The way I shorten/splice cables at work is
I usually solder a stainless cable into a loop. holds a million times better than a crimp.
fasted58
fasted58 UltraDork
4/15/12 4:59 p.m.
pick n pull
mad_machine
mad_machine MegaDork
4/15/12 6:08 p.m.
how long is too long? I would think the only parts you need to worry about are the bits outside the sheath.. anything inside the sheath you can route as necessary to take up excess distance
JoeyM
JoeyM SuperDork
4/15/12 6:20 p.m.
mad_machine wrote: how long is too long? I would think the only parts you need to worry about are the bits outside the sheath.. anything inside the sheath you can route as necessary to take up excess distance
probably a foot or more....the end of the cable is over the differential How sharply can I bend the sheath without causing problems?
iceracer
iceracer SuperDork
4/15/12 6:48 p.m.
They used to make cable shorteners for when they streched. don't know if they still do.
Taiden
Taiden SuperDork
4/15/12 7:40 p.m.
Napa sells screw on clutch cable stops. I figure you could probably use those to make new stops.
mad_machine
4/16/12 7:34 a.m.
that I don't know.. but is there anyway you can put a couple of loose "s"s in it before it reaches the diff?
JoeyM
JoeyM SuperDork
4/16/12 8:51 a.m.
I may have to....I made the transmission tunnel too tall. Will try to take pics this afternoon.
qJhxEuyv8irQjg7ukQTclhPVeph2OktpDrQZhHlWUUQcBaLwRb0WUkbXPmfdHWjl
