Grtechguy
Grtechguy MegaDork
5/23/16 8:01 p.m.
What sort of input would this be?
It's attached to this:
jamscal
jamscal Dork
5/23/16 8:10 p.m.
Dryer or stove plug. A regular 'welders plug' is a nema 6-50p but what you have will work (assuming you have the receptacle to match).
Home depot/Lowes etc will have either.
mad_machine
mad_machine MegaDork
5/23/16 8:15 p.m.
if only you knew how many different plugs there are out there
Grtechguy
Grtechguy MegaDork
5/23/16 8:20 p.m.
Well, I don't have a receptical anywhere close to this in the garage, but I do have a sub-breaker box.
How should it be wired? Is this 220/20amp? 40amp?
TRoglodyte
TRoglodyte UltraDork
5/23/16 8:26 p.m.
Amp draw may be stamped on plug, I'm guessing 30 amp.YMMV.
stuart in mn
stuart in mn UltimaDork
5/23/16 9:31 p.m.
Here's a chart showing various NEMA plug and receptacle styles. I think that's a 50 amp but you'll have to confirm.
http://www.generatorjoe.net/html/web/outlet/nemaspecs.gif
Hal
Hal UltraDork
5/23/16 9:41 p.m.
stuart in mn wrote: Here's a chart showing various NEMA plug and receptacle styles. I think that's a 50 amp but you'll have to confirm. http://www.generatorjoe.net/html/web/outlet/nemaspecs.gif
Looks like a 10-50 to me. Standard stove stuff.
paranoid_android74
paranoid_android74 SuperDork
5/23/16 10:28 p.m.
Just for good measure I'd check the "nameplate" rating on the welder. Should be a sticker on it somewhere.
44Dwarf
44Dwarf UltraDork
5/24/16 8:24 a.m.
220v 50amp the 30 amp has a 90 deg bend in the ground prong make it look like an L
Ian F
Ian F MegaDork
5/24/16 9:15 a.m.
In reply to Grtechguy:
You'll need a 10-50R receptacle connected to a 50A, 2-pole breaker in the panel. Check the feeder breaker feeding this sub-panel before continuing. It's not uncommon for a panel to be labeled at a higher rating than what it is fed with.
Grtechguy
Grtechguy MegaDork
5/24/16 9:37 a.m.
Thanks, I'll take a look. I'm thinking I only have 40 amp feeding it.
So, here's another question, If I'm not running this thing anywhere near full potential, does it pull the high amperage? I can't see myself ever welding anything over 1/4" (and that would be a stretch)
Dr. Hess
Dr. Hess MegaDork
5/24/16 12:03 p.m.
A 20 amp 220V circuit might be enough. 40 would be fine. If you don't have it cranked all the way up, it doesn't draw as much current. That's how Physics works. For 1/4" plate, I would SWAG that at 80 amps at the work, maybe 20 Volts? 1600 Watts = 7 amps at the plug. SWAG it at 10 or 15 Amps.
Trace the prongs on a piece of paper and bring that to Lowes, then match up your trace on the plugs available. That's what I do. It is amazing how many of those plugs are out there and look very similar.
Javelin
Javelin MegaDork
5/24/16 12:10 p.m.
Came in expecting some sort of ethics question involving electrocuting people running for election.
Going away highly disappointed...
8ed7yOyiosaHjg5Ldjrmz52QP7DSRmSAQMd1kYkX3trxAZlQCVfva4LjswhoBhpI
