924guy
924guy Dork
12/21/10 9:42 p.m.
unbolt tube, raise car...
Photobucket
drag tube and rear carrier away from car.
Photobucket
lower car..
Photobucket
the end
Toyman01
Toyman01 SuperDork
12/21/10 9:46 p.m.
Hmmm
Lesley
Lesley SuperDork
12/21/10 10:04 p.m.
What in god's name is a torque tube?
Toyman01
Toyman01 SuperDork
12/21/10 10:12 p.m.
The big tube looking thing down the middle. Used to connect a front engine to a rear transmission. Usually buried deep inside a car where you can't get to it without dismounting the world.
924guy
924guy Dork
12/21/10 10:15 p.m.
Lesley wrote: What in god's name is a torque tube?
think drive shaft...
Lesley
Lesley SuperDork
12/21/10 10:17 p.m.
OK, drive shaft I know. Changed the bloody hanger bearings on my truck one time.
Toyman01
Toyman01 SuperDork
12/21/10 10:25 p.m.
Yuck, I have never had a hanger bearing change go by the book. The last two I have done I ended up shattering the outer race and cutting the inner race off the shaft.
I sure hope you had better luck with yours.
Lesley
Lesley SuperDork
12/21/10 10:29 p.m.
I had help that knew what they were doing, thank god.
WilberM3
WilberM3 HalfDork
12/22/10 8:15 a.m.
Lesley wrote: OK, drive shaft I know. Changed the bloody hanger bearings on my truck one time.
the difference is that a torque tube is a fixed tube connecting an engine and trans, with a driveshaft inside it.
Lesley
Lesley SuperDork
12/22/10 9:32 a.m.
Gotcha... it's the thing the driveshaft lives in.
pilotbraden
pilotbraden Reader
12/22/10 9:56 a.m.
Is a hanger bearing also called a carrier bearing?
1slowcrx
1slowcrx HalfDork
12/22/10 9:58 a.m.
pilotbraden wrote: Is a hanger bearing also called a carrier bearing?
Center support bearing on BMW's and Benz
iceracer
iceracer Dork
12/22/10 10:23 a.m.
Torque tubes have also connected the transmission to the rear axle. Mostly on older cars.
wlkelley3
wlkelley3 Dork
12/22/10 11:31 a.m.
Torque tubes don't always connect the transmission to the rear axle. My Opel GT uses what they call a torque tube that solidly connecte the rear axle to the unibody and the drive shaft hooks to it.
iceracer
iceracer Dork
12/22/10 5:31 p.m.
And there is a driveshaft inside the torque tube. Not familiar with Opels though.
wbjones
wbjones Dork
12/22/10 6:53 p.m.
so a torque is a housing for a drive shaft...???? and this helps the drive shaft how ????
porksboy
porksboy SuperDork
12/22/10 8:04 p.m.
Centre support bearings get the drive shaft removed and then the whole shebang gets toted to my buddies at the drive shaft shop 5 miles from the house. They will replace the bearings and u-joints and rebalance everything for $50.00.
wlkelley3
wlkelley3 Dork
12/22/10 9:54 p.m.
Opel GT rear axle Yeah, basically a housing for a shaft. The attached link is a breakdown of the Opel GT axle. The section from the diff to a carrier is what they call a torque tube and does have a shaft in it. In this case it also act as a pivot point, sort of. The drive shaft has universals but mainly stays straight.
4QIUtfYZqtFIdYwRwl76foyki1naw9i2yGz9LLO7hXySpselQSKcr1SBBI4wl4RC
