turboswede
turboswede SuperDork
1/25/10 12:54 p.m.
http://www.weberprecision.com/
How about something like (perhaps slightly larger) powering a bar stool or a yard kart?
Here's a magazine that specializes in this stuff:
http://www.modelenginebuilder.com/
I've been to a couple of the shows they put on and it is very, very cool looking at, hearing and smelling what these engines do. Walking in the building at one of these shows, you get a sense that there is a lot of knowledge and fun to be had. Then someone fires up one of the model V8's and all rational thought stops for a moment and you turn into a kid again.
Enjoy!
Toyman01
Toyman01 Dork
1/25/10 4:34 p.m.
I subscribe to that mag. There are definitely some smart people out there. I have built a couple of one lung steam engines, but I doubt I will ever have the skill or patience to build a V8. Very cool stuff there.
Spinout007
Spinout007 HalfDork
1/25/10 10:33 p.m.
turboswede wrote: ... all rational thought stops for a moment and you turn into a kid again. Enjoy!
heh sounds like every time I turn a wrench on our challenge car!
Ian F
Ian F Dork
1/26/10 7:00 a.m.
turboswede wrote: http://www.weberprecision.com/
Holy crap! Did you look at the shop tour pics?
I have serious tool-envy.
4cylndrfury
4cylndrfury Dork
1/26/10 7:08 a.m.
how bout a 1/3 scale Cheby 350:
Here is a link to how this guy scaled down, cast in aluminum, and built this by hand!!!!
RossD
RossD Dork
1/26/10 7:23 a.m.
I'll probably never be able to do anything nearly this cool, but I'd want the engine to be roughly half size. Maybe try to cast in a full size bellhousing pattern of a small 4 cylinder. 2.65 liter pushrod V8 sounds great for a locost or MG. Dont know if I'd trust it if I made it though; now that guy...I'd consider it.
I mean use your evil powers for good, not just to show off.
4cylndrfury
4cylndrfury Dork
1/26/10 9:42 a.m.
The problem is that when you scale down the engine, the HP scales down much more rapidly...that 350 only puts out an estimated 5-8 hp...not sure on torque. I guess its because while the engine scales down - i.e. the combustion chamber gets smaller - the fuel and air dont. So when you go to fire on the power stroke, the confines change the dynamics of combustion, and therefore the power is significantly decreased.
turboswede
1/26/10 10:13 a.m.
4cylndrfury wrote: The problem is that when you scale down the engine, the HP scales down much more rapidly...that 350 only puts out an estimated 5-8 hp...not sure on torque. I guess its because while the engine scales down - i.e. the combustion chamber gets smaller - the fuel and air dont. So when you go to fire on the power stroke, the confines change the dynamics of combustion, and therefore the power is significantly decreased.
Take your logic and reasoned replies and stuff em! We're talking about fantasies here man! :)
Matt B
Matt B Reader
1/26/10 10:34 a.m.
Must be why the engine at the top uses a blower
4cylndrfury
4cylndrfury Dork
1/26/10 10:52 a.m.
logic + reason + 4cf only happen every once and a while, so I had to share while the moons of uranus were in alignment.
Now that things are back to normal, I can now comfortably say boosted V8 baby engine in a shiftercart FTMFW
RossD
RossD Dork
1/26/10 11:06 a.m.
I think casting inconel turbines will be hard. (pun intended)
xci_ed6
xci_ed6 HalfDork
1/26/10 2:17 p.m.
Instead of scaling them down, you would need to change the entire design. Low displacements make high power with high revs, so relatively enlarge the bores and shorten the stroke. Maybe even change the valve layout and combustion chamber shape. Pushrod multi-valve hemi....
I also think a pushrod V4 would be pretty neat after seeing: http://www.autoblog.com/2010/01/20/motus-motorcycles-details-new-v4-engine-mts-01-sport-tourer/
Toyman01
Toyman01 Dork
1/26/10 2:23 p.m.
xci_ed6 wrote: Instead of scaling them down, you would need to change the entire design. Low displacements make high power with high revs, so relatively enlarge the bores and shorten the stroke. Maybe even change the valve layout and combustion chamber shape. Pushrod multi-valve hemi.... I also think a pushrod V4 would be pretty neat after seeing: http://www.autoblog.com/2010/01/20/motus-motorcycles-details-new-v4-engine-mts-01-sport-tourer/
140hp and 120 torque, forget the motorcycle. It's got more power than my Mazda.
Keith
Keith SuperDork
1/26/10 2:28 p.m.
I think that learning how to do your own casting would open up a huge range of potentially interesting things. Heck, the main skills needed to build a lot of those classic racers in the 1960's were the ability to make castings, weld and lay fiberglass.
xci_ed6
xci_ed6 HalfDork
1/26/10 2:38 p.m.
What if you hacked 4 cylinders out of the middle of an aluminum LSX block?
RossD
RossD Dork
1/26/10 3:05 p.m.
You'd have two aluminum V-twins left.
4cylndrfury
4cylndrfury Dork
1/26/10 3:19 p.m.
pushrod I4s are available in any 2 liter chevy from the 80s and 90s..their called cavaliers and corsicas lol
someone famous once said "all the technology of heavy V8s, only half the weight" hahaha
xci_ed6
xci_ed6 HalfDork
1/26/10 3:53 p.m.
RossD wrote: You'd have two aluminum V-twins left.
I should have finished...
...then weld the two v-twins together.
Ian F
Ian F Dork
1/26/10 4:32 p.m.
...or you'd end up with an early 70's Saab...
Keith
Keith SuperDork
1/26/10 5:21 p.m.
I should have finished... ...then weld the two v-twins together.
Then you'd have two aluminum pushrod V4s, one of which would be missing little things like a water pump
HBr1qjbXsm0MZJDprRzgJpBr9ydIwTqPlXuMKJy83QM1BY69mnx1Wm3pdbUHCE3o
